Old 21st February 2018, 08:07 PM
carl81 carl81 is offline
Default For Sale Audi S8 D2 2002 Spares or Repairs
For Sale Audi S8 2002
Good bits:
81,000 miles
MOT till Sept 2018
Bodywork in great condition for the year, only the odd blemish here and there
Xenon Lights
Sat Nav
Immaculate interior
New brake pads and rear calipers
Gearbox perfect
Oil change less than 500 miles ago
Battery 18 months old
Plenty of Service History
Bad bits:
1. Car is suffering from an overheating issue. The temp gauage will continue past 90 degrees which I know is not normal as it usually sits bang on 90 degrees. Have only driven a short distance so have never even gone to 100 degrees. Car heater stays warm.
2. Cracked windscreen
3. The roof needs to be resprayed as the lacquer has come off due to a car cover in combination with freezing weather
4. Central locking seems to be temporamental. I can pair the key with the car, but it seems to unpair a few days / weeks later.
5. Parking Sensors do not work. It is the front drivers side that is faulty.
Because of the overheating issue I wouldn't recommend driving much of a distance so will need to be towed away. Hence sold as seen / spares repair
£1895 ono
Car is located in Rutland.
For for info call 07720851128
ID:	18021   Click image for larger version
ID:	18022   Click image for larger version
Old 21st February 2018, 08:22 PM
Welcome to the forum. We have another member quite near you (near Belvoir)
At that mileage it surely deserves to be fixed, nothing sounds too horrendous for the right enthusiast. So hopefully it won't be scrapped.
Overheating could just be a faulty CTS, or worse thermostat (bit of a PITA to swap).
It surely must have some extras not listed above.
Old 21st February 2018, 08:39 PM
+1. Nice looking car on the face of it.
Old 21st February 2018, 08:50 PM
Hi,
Thanks for the reply. Thermostat has been done, genuine Audi part. Hence the ad. I'm not getting any erratic temps hence why not convinced its the CTS? Just a steady rise higher and higher. Also I let the car idle for 15 mins after replacing the thermostat. Bang on 90 degrees. Only when I began to drive it crept over 90.
Are they hard to replace?
Cheers.
Old 21st February 2018, 08:52 PM
Quite easy (and cheap); bit fiddly and care is needed to ensure you don't lose the clip down in the engine bay.
I posted a thread ages ago on how I did mine, will link to it if I can find it. It's still fine over 4 years later.
Edit, no I didn't, I just added to this one; read it all (post 17 is my initial summary): http://forum.a8parts.co.uk/showthread.php?t=1157
Getting the plug off seems to be the biggest problem.
Old 21st February 2018, 09:12 PM
Has it ever had a timing belt? What can happen is the hydraulic belt tensioner fails and allows the belt to go slack on over-run. When that happens it stops driving the water pump so no coolant flows round the engine and it over heats (had one in like that last year). Worst-case scenario when the belt snatches the pump on acceleration the torque spike loosens the impeller (cast iron on these so lots of intertia) and after a while the impeller simply falls off the shaft. That happened on mine (before I got it!).
If you do want to persever with it, I'd suggest a genuine exchange water pump and INA timing belt kit with the tensioner (essential) would sort it right out, but that's not a cheap job.
