After Auto-Scan I have this fault code:
Code:
------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H10 0190 Revision: 01904910 Serial number: AUX3Z0G0315418 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58B5B80DEBE2FD8400-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX 1 Fault Found: 00193 - Rear Right Door Handle Touch Sensor (G418) 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 3 Fault Frequency: 0 Reset counter: 171 Mileage: 286336 km Time Indication: 0 Date: 2018.03.15 Time: 13:38:32 ------------------------------------------------------------------------------- And if it is possible will the keyless entry still work? If you think about it if you disable only one sensor it should, right? Any detailed info how to do this? If needed there is full Auto Scan below. (I also have a question about other code, but I guess I should ask it in the different section). And I know that I still haven't say hi and posted photos, will try to do it soon. I just had first off from work in two months and need to clean my beauty first and then will do proper introduction ![]() Code:
Thursday,15,March,2018,13:39:20:61846 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86 VCDS Version: 18.2.0.3 Data version: 20180212 DS287.0 www.Ross-Tech.com VIN: WAUZZZ4E17N016208 License Plate: YS07SZT Mileage: 177923mi Repair Order: After Coding -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 4E (4E0) Scan: 01 02 03 05 06 07 08 09 0F 15 16 17 18 19 1D 1E 25 34 36 37 38 42 46 47 4F 52 53 56 57 61 62 67 72 76 77 VIN: WAUZZZ4E17N016208 Mileage: 286340km-177923miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 0F-Digital Radio -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 18-Aux. Heat -- Status: Malfunction 0010 19-CAN Gateway -- Status: OK 0000 1D-Driver Ident. -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: OK 0000 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 67-Voice Control -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 059-907-401-ASB.clb Part No SW: 4E0 910 402 E HW: 4E0 907 401 D Component: 3.0L V6TDI G000AG 0020 Revision: --H04--- Serial number: AUX3Z0G0315418 Coding: 0311973 Shop #: WSC 02629 005 00000 VCID: 1E39EE15C94643B40A-804A 1 Fault Found: 004120 - Intake Manifold Runner (Bank 2) P1018 - 001 - Lower limit not reached Freeze Frame: Fault Status: 01100001 Fault Priority: 0 Fault Frequency: 2 Reset counter: 255 Mileage: 286348 km Time Indication: 0 Date: 2018.03.15 Time: 13:29:13 Freeze Frame: RPM: 0 /min Torque: 0.0 Nm Speed: 0.0 km/h Voltage: 12.01 V Duty Cycle: 20.5 % Duty Cycle: 88.8 % Duty Cycle: 20.5 % Readiness: 0 0 1 1 1 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 09L-927-760.lbl Part No SW: 4E1 910 156 Q HW: 09L 927 156 A Component: AG6 09L 3,0 TDI RdW 0020 Revision: --H01--- Serial number: 4281381 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 316325A9A8D8CCCCA7-8064 No fault code found. ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.lbl Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC Component: ESP 5.7 allrad H46 0510 Coding: 0008357 Shop #: WSC 02313 000 00000 VCID: 2241DAE5FD3E67542E-8076 No fault code found. ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H10 0190 Revision: 01904910 Serial number: AUX3Z0G0315418 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58B5B80DEBE2FD8400-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX No fault code found. ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory BFS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063328 Shop #: WSC 02313 785 00200 VCID: 244DDCFDE72A69645C-8070 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.lbl Part No SW: 4E0 910 769 Q HW: 4E0 035 729 A Component: Interfacebox H43 5570 Revision: 00000000 Serial number: 300AG077578402 Coding: 0000002 Shop #: WSC 00000 000 00000 VCID: 3A71028575AE0F9416-806E Subsystem 1 - Part No: 4E0 910 611 Component: E0380 BedienteilH01 0040 Subsystem 2 - Serial number: 00000000030289 Subsystem 3 - Serial number: 0102.02.070000000100010037ÿ Subsystem 4 - Serial number: 010037ÿ No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 G Component: KLIMAAUTOMAT 017 0450 Revision: 00000032 Serial number: 00000000113759 Coding: 0018467 Shop #: WSC 02311 785 00200 VCID: 1C3DE41DDF5A51A4E4-8048 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.lbl Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q Component: ILM Fahrer H15 0230 Coding: 0103121 Shop #: WSC 02313 785 00200 VCID: 366916B541B6EBF4F2-8062 Subsystem 1 - Part No: 4E2 910 113 C Component: Wischer WWS D3 H60 0440 Coding: 00000036 Shop #: WSC 02313 Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB Component: REGENLICHTSENSORH13 0090 Coding: 01719111 Shop #: WSC 02313 No fault code found. ------------------------------------------------------------------------------- Address 0F: Digital Radio Labels: None Part No SW: 4E0 910 563 C HW: 4E0 035 563 Component: DAB-Tuner H41 0830 Revision: 00000001 Serial number: KE1276V7800834 Coding: 0000001 Shop #: WSC 00196 210 83196 VCID: 244DDCFDE72A69645C-8070 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-94.lbl Part No SW: 4E0 910 655 D HW: 4E0 959 655 H Component: Airbag 9.41 H14 4210 Revision: 91H14421 Serial number: 0037P0G07R43 Coding: 0431707 Shop #: WSC 02313 785 00200 VCID: 2757CBF1961C827C79-8072 Subsystem 1 - Serial number: 63328RB4020ABB67P Subsystem 2 - Serial number: 63428RB4020ABB51J Subsystem 3 - Serial number: 63528RB4020ABBB2R Subsystem 4 - Serial number: 63628RB4020ABBC2T Subsystem 5 - Serial number: 63729RB401E55D2AX Subsystem 6 - Serial number: 63829RB401E55B78Z No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.lbl Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H14 0040 Coding: 0112041 Shop #: WSC 02311 785 00200 VCID: 65CB81F9AC90506C8B-8030 Subsystem 1 - Part No: XXXXXXXXXXX Component: Lenkradmodul H07 0090 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.lbl Part No SW: 4E0 910 951 B HW: 4E0 920 951 B Component: KOMBIINSTR. VDO H82 0530 Revision: D04 Serial number: AUDID3G1000984 Coding: 0000403 Shop #: WSC 00196 067 57207 VCID: 244DDCFDE72A69645C-8070 No fault code found. ------------------------------------------------------------------------------- Address 18: Aux. Heat Labels: None Part No SW: 4E0 910 105 A HW: 4E0 815 069 G Component: Heizgeraet H08 0140 Revision: 0000000C Serial number: 00000009013887 Coding: 0000011 Shop #: WSC 00000 000 00000 VCID: 1A31E205D56E2F94F6-804E 2 Faults Found: 02245 - Connection; RF Remote Control 004 - No Signal/Communication 01408 - Under-Voltage Shut-Off (fixed Value) 000 - - ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels:. 4E0-910-468.clb Part No SW: 4E0 910 468 B HW: 4E0 907 468 E Component: Gateway H11 0090 Revision: 11 Serial number: 2000306B098099 Coding: FCFF5BDE2B7D04 Shop #: WSC 02313 785 00200 VCID: 2757CBF1961C827C79-8072 No fault code found. ------------------------------------------------------------------------------- Address 1D: Driver Ident. Labels: 4E0-910-218.lbl Part No SW: 4E0 910 218 A HW: 4E2 905 218 B Component: FPI_1 H01 0020 Revision: 01000102 Serial number: 26062008195458 Shop #: WSC 00000 000 00000 VCID: 1F47D311CE4C4ABC01-804A No fault code found. ------------------------------------------------------------------------------- Address 1E: Media Player 2 Labels: 4E0-910-111.lbl Part No SW: 4E0 910 110 E HW: 4E0 035 110 A Component: MP3-Changer H44 0390 Revision: 00044000 Serial number: AUZ5ZBG3150517 Shop #: WSC 00000 000 00000 VCID: 1A31E205D56E2F94F6-804E No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 4E0-910-131.lbl Part No SW: 4E0 910 131 HW: 4E0 909 131 K Component: FBS AUDID3 H10 0190 Revision: 01904910 Serial number: AUX3Z0G0315418 Coding: 0412672 Shop #: WSC 02311 785 00200 VCID: 58B5B80DEBE2FD8400-800C Subsystem 1 - Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX 1 Fault Found: 00193 - Rear Right Door Handle Touch Sensor (G418) 007 - Short to Ground Freeze Frame: Fault Status: 01100111 Fault Priority: 3 Fault Frequency: 0 Reset counter: 171 Mileage: 286336 km Time Indication: 0 Date: 2018.03.15 Time: 13:38:32 ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.lbl Part No SW: 4E0 910 553 H HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 4480 Coding: 0013310 Shop #: WSC 02313 785 00200 VCID: 2855C8CD9B028D0470-807C No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 D HW: 4E0 959 760 B Component: Sitzmemory FS H02 0010 Revision: 00000000 Serial number: 5DS 008 795-03 Coding: 4063342 Shop #: WSC 02313 785 00200 VCID: 244DDCFDE72A69645C-8070 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.lbl Part No SW: 4E0 910 888 P HW: 4E0 919 887 L Component: MNS ECE H48 1060 Revision: 00000000 Serial number: 364BQ077635407 Shop #: WSC 00732 210 88528 VCID: 3B7F07817A94369C0D-806E No fault code found. ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.lbl Part No SW: 4E0 910 135 A HW: 4E0 907 135 A Component: Dachknoten D3 H05 0090 Serial number: 00000701600008 Coding: 0036036 Shop #: WSC 02313 785 00200 VCID: 1D3BE919C44058AC13-8048 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 802 D Component: Türsteuer.FS BRM005 0180 Coding: 0032622 Shop #: WSC 02313 785 00200 VCID: 2045D0EDF332754438-8074 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels:. 4E0-910-289.lbl Part No SW: 4E0 910 289 D HW: 4E0 907 289 D Component: Komfortgeraet H08 0020 Revision: 00200008 Serial number: W040701300519 Coding: 0004317 Shop #: WSC 02313 785 00200 VCID: 2A5132C5850EBF1466-807E Subsystem 1 - Part No: 4E0 907 719 Component: Neigungssensor H05 0020 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.lbl Part No SW: 4E0 910 223 R HW: 4E0 035 223 G Component: DSP-High D3 H03 0120 Revision: PROD_01 Serial number: 00000000001934 Coding: 0000023 Shop #: WSC 02313 785 00200 VCID: 2C5D34DD8FFAA12494-8078 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H11 0070 Revision: Serial number: 00000000103581 Coding: 0010001 Shop #: WSC 02313 785 00200 VCID: 1E39EE15C94643B40A-804A No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl Part No SW: 4E1 910 802 B HW: 4E2 959 801 D Component: Türsteuer.BF BRM005 0180 Coding: 0032262 Shop #: WSC 02313 785 00200 VCID: 2045D0EDF332754438-8074 No fault code found. ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: 4E0-910-801.clb Part No SW: 4E0 910 801 D HW: 4E0 907 801 B Component: EPB A4EC0230 H03 0230 Revision: --H03--- Coding: 0000221 Shop #: WSC 00294 210 01865 VCID: 2045D0EDF332754438-8074 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.lbl Part No SW: 4E0 910 541 T HW: 4E0 035 541 S Component: TUNER EU/US/RDW H42 0630 Revision: 00000000 Serial number: 396BZ077559253 Coding: 0000001 Shop #: WSC 02313 785 00200 VCID: 316325A9A8D8CCCCA7-8064 No fault code found. ------------------------------------------------------------------------------- Address 57: TV Tuner Labels: None Part No SW: 4E0 910 148 E HW: 4E0 919 148 Component: R0078 TVhybridT 0470 Revision: R0H06000 Serial number: 76300800243101 Coding: 0000003 Shop #: WSC 02313 785 00200 VCID: 254BC1F9EC10906C4B-8070 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.lbl Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0550 Revision: 00000000 Serial number: 00000000000689 Shop #: WSC 00732 210 88528 VCID: 2045D0EDF332754438-8074 Subsystem 1 - Part No: 4E0 915 105 A Component: von VA0 2702080133 Coding: 344530393135313035412056413032373032303830313333 Shop #: WSC 12345 128 00289 No fault code found. ------------------------------------------------------------------------------- Address 62: Door, Rear Left Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 801 D Component: Türsteuer.HL BRM005 0180 Coding: 0039246 Shop #: WSC 02313 785 00200 VCID: 1E39EE15C94643B40A-804A No fault code found. ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.lbl Part No SW: 4E0 910 754 S HW: 4E0 035 753 A Component: SDS 3502 UK H45 0630 Revision: 00000000 Serial number: 00000702020245 Shop #: WSC 12336 024 394758 VCID: 366916B541B6EBF4F2-8062 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.lbl Part No SW: 4E0 910 802 A HW: 4E0 959 802 D Component: Türsteuer.HR BRM005 0180 Coding: 0039246 Shop #: WSC 02313 785 00200 VCID: 1E39EE15C94643B40A-804A No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.lbl Part No SW: 4E0 910 283 C HW: 4E0 919 283 C Component: Parkhilfe 8-Kan H12 0040 Revision: 00H12000 Serial number: 08720701801032 Coding: 0301008 Shop #: WSC 02313 785 00200 VCID: 234FDFE1E2246E5C25-8076 No fault code found. ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.lbl Part No SW: 4E0 910 336 M HW: 4E0 862 335 Component: Handyvorb2 H18 1130 Revision: 00000000 Serial number: 00000005143083 Coding: 0010900 Shop #: WSC 00196 210 90060 VCID: 2C5D34DD8FFAA12494-8078 No fault code found. End-------------------------(Elapsed Time: 03:53)-------------------------- Last edited by Leorio; 15th March 2018 at 02:47 PM. Reason: Forgot to add info |
The fault is referring to the touch sensor, not the button.
I've got that same fault intermittently on all my doors, it does not seem to affect the function of the keyless apart from having to lift the handle twice from locked to open the door. I also have lots of other faults in a VCDS scan but none affect the car dramatically, for example my rear footwell heaters are dead and the recirculation motor for the heater (engine bay) is jammed open. My car is 15 years old and I am realistic in expecting to have some minor faults that are not cost effective to repair, mostly because parts are becoming no longer available and you'd need to use secondhand parts to replace broken ones, and they may not last long.
Parts becoming nla for the D3!?! Wait is there something I need to know about VAG repair part availability?? Only since a year the parts for my 97 M3 are starting to dry up... Which is 10 years older than the s8
Also would like to know if there is a way to disable kessy for fault searching purposes (without it keeping the modules out of standby) |
NLA = no longer affordable
![]() I was charged £42 for a connector and 4x 6" repair wires at TPS! People on here taling about £60+ wiper blades. Seems to be how Audi get away with low spares stock, just jack the price up inverse-exponentially. |
