Old 15th March 2018, 09:01 PM
Default 4.2 TDi Glow plug (near) disaster
My 4.2 Tdi was struggling to start when cold.
VCDS confirmed 4 glow plugs wern't working.
As the glow plugs are on the top of the engine and reasonably easy to access, it seemed logical to replace all 8 as they're relatively cheap items.
Out of the 8, 4 came out ok, and were replaced.
1 left its thread behind in the head.
1 snapped the head off leaving the plug embedded in the head.
The other 2 we chickened out on....
So, a number of phone calls later (I can't take credit, it was Maria actually) and most people said it was head off and drill them out, but we ended up being passed along to one guy who's only job in life (literally) is to remove stuck glow plugs and injectors from diesels heads....
Sadly I wasn't there, but we removed the (few in this case) items that were blocking his easy access to the plugs, he setup his mega expensive spirit level based equipment and drilled precisely down the middle of the glow plug with a counter threaded removal tool. I've used them before, you basically drill in reverse until it bits and forces the screw / bolt etc out, but this was done with millimetric levels of precision.
The result is the 2 failed ones removed, the snapped one removed, and using some other specialist tools he went into the hole and came back up cleaning out the threads for the last one.
Basically, good as new.
Pricing was something along the lines of £200 for the first one, £100 for the second and £50 each after that. Plus VAT, plus travel mileage.....
Not pocket change, but massively less disruptive than taking the heads off for sure....
The remains of the old ones. On the far right you can see the one that stripped its threads and left them behind in the head:
The newly created threads inside as a result of the extraction tools:
And this tub is full of all the metal parts - Nothing went in the engine, of this he was most certain and proud.....
Runs sweet as a nut now, starts from cold like its fully warmed up. Brilliant
ID:	18144   Click image for larger version
ID:	18145   Click image for larger version
ID:	18146   Click image for larger version
Old 15th March 2018, 09:33 PM
Good stuff I'm surprised how much swarf can be made from glow plugs!
Old 15th March 2018, 10:52 PM
H-M3 H-M3 is offline
Sheeesh! That’s scary. Dreading my one.
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 16th March 2018, 06:16 AM
I've never seen anything like that, amazing work!
Old 16th March 2018, 08:30 AM
Bloody hell! Hear of this kind of thing but never seen the pictures.
What make are the plugs BERU? BOSCH? Not very impressive how they aren't strong enough to withstand being unscrewed after their life is up.
Old 16th March 2018, 08:33 AM
Quite often the same issue with lambda probes - the problem in both cases isn't helped by the harshness of the environment they're sitting in, the fact they won't be removed between new install and failure, their purpose is to provide heat so they heat cycle a lot.
Good to know people provide these services - I imagine it'd cost a fair wedge more down this neck of the woods!
A
