Hi There,
A while back at work i left my sunroof open and didn't realise the rain until too late. It wasn't a massive amount of water and i dried everything off and it was reasonable if a stupid move ![]() Anyway after that the red back lights in the center console have been iffy. Sometimes pressing would get them on, sometimes they'd work and now they've just given up the ghost. It's not a major hassle and i know where the CD or NAV button is by now, but occasionally they'd be useful, so am thinking of finally looking at the issue!!! Any pointers as it's a bit i've not removed on the D3 etc
Current : 2005 A8 Sport 4.2 V8 D3 - LPG working! Previous : 1998 S8 PF 4.2 V8 D2 - Gearbox died ~120k 2002 S8 FL 4.2 40v V8 D2 Prins LPG - Engine valves met pistons ~230K Also : 1996 Jeep Grand Cherokee 4.0l (Post Apocalyptic makeover) 2003 Brabus Smart FourTwo (should sell) 2003 Mazda Rx8 2.3 (might sell) |
You have to buy some 99% isopropyl such as from cpc farnell and then take out the PCB and flush it to remove the water.
As far as I remember, remove the ashtray, remove some screws, remove the something else and maybe 2 more screws under that hold the centre console in then it lifts out. There are about 5 plugs to take out, remove them and then take in the house. Remove the back plastic, EPB switch and maybe start button (check this instructions in SSP as there is a trick with a sliding pin) and then wash the PCB in the sink and leave until dry about 15 mins and then put all back together. You might be able to do this without removing the PCB via the gaps, but I would worry about the isopropyl affecting the soft touch coating on the MMI buttons, it seems to go soft when damp. The isopropy is very miscible in water and not conductive so will displace the moisture in all the nooks and crannies and microswitches and will dry off quite quickly due to it's volatility. |
Have same issue , Try it to wash it , but its didn't help me..... Anyone across UK fixing MMI ? I can simply send over mine 3g high mmi panel... Thanks
Are all the lights off or just some? If all there must be a single point of failure. If just a few, may be the LEDs themselves and you could perhaps get new SMDs (surface mount diodes) of the correct size.
There is a 1A fuse for illumination, maybe worth checking....
So mine problem is like , MEDIA and RADIO button completely not working , So I can press Telephone and maybe it will switch Media or Radio or telephone...
So basically not working properly just 4 buttons on the left side of console , all rest is working as should How to get it fixed? PS- All LEDs is working on mine fine |
