Old 15th May 2018, 03:52 PM
karlcossy karlcossy is offline
Default Instrument panel miles correction
CAN SOMEONE HELP CHANGED DASH WHEN I PUT ACC IN AND NEED TO MATCH MILES WITH OLD ONE AS DONT WANT SOMEONE MOANING WHEN I SELL IT ON
Old 15th May 2018, 06:29 PM
When you plug in VCDS, the first thing you need to do is turn your caps lock off
Beyond that, I cannot help, sorry!
Old 15th May 2018, 06:36 PM
Officially, a cluster can only be rolled forward using vagcom to a new value if it has less than 100km on the mileage. Once past this, it becomes locked.
Unofficially, I believe it can be done, but i believe its a soldering iron job on the bench job. I'm not aware of anyone on this forum that has even proceeded past the 'how do i' stage and actually gone to effort of doing it properly.....
The A8 is a high value car, so they have done a decent job of making it quite hard to clock from what i read.....
Old 15th May 2018, 06:45 PM
When I put a 2008 wide DIS cluster in my 2006, it took quite a while to clock it forward. Eventually, a friend of an ex work colleague wanted to borrow my VCDS and in return I borrowed some hand held thing that could change the mileage via the OBD port.
Like this..
https://www.youtube.com/watch?v=FGbHt6gvZm0
It took quite a few goes and required removing fuses, counting seconds, turning ign on and off and counting more seconds and putting fuse back and was quite complicated - it took me almost an hour of trying stuff and googling.
Still had one MOT with the very low mileage.
Attachment 18880
Old 15th May 2018, 07:57 PM
oops kids again i was shouting
Old 15th May 2018, 08:00 PM
did try on vcds but no luck kept saying error when putting figure in so ill have to see my man to sort via obd
Old 15th May 2018, 11:11 PM
H-M3 H-M3 is offline
Something I will need to do too as I am in the process of changing cluster. PM Marcin on this forum as he did a detailed thread on this
Audi A2 1.4 petrol 2002
NO VCDS rely on Neeldub
Old 16th May 2018, 08:32 AM
This is something I could do. I just need the cluster. You could post it to me before you install it and I can :
Reset the mileage to what you want;
Or to virgin state and you use VCDS to alter it when you're ready - but you'll have only one change with VCDS with values over 100km's.
You'll then have CP to remove once installed.
Oh Wicked. Ps pm details👍🏼
Old 16th May 2018, 09:19 AM
Nice, and good to know....
Any chance of back filling a few more of the technical details of whats involved ? Not looking to steal any business away from you, but as an IT guy, I find this quite interesting.. .
Old 17th May 2018, 05:38 AM
1781cc 1781cc is offline
Brilliant
