Hi all, I went to see a lovely S8 today and I am very close to pulling the trigger. The seller (trade) was happy for me to do a scan and left me to it so i did after a test drive. The car drove beautifully and all the electrics work bar the button on the driver's door (lock) handle. Are these anything to worry about or any expensive to fix? The parking brake fault for the rear sensor I am hoping is a wear sensor as the car has ceramics!
Any help appreciated 1. 005491 - Left Engine Mount Solenoid Valve (N144) P1573 - 004 - Open Circuit 2. 02596 - Rear Brake Pads Worn 008 - Implausible Signal 3. 006435 - Please Check DTC Memory of ECU Number 2 P1923 - 008 - Code:
Gateway Installation List: 4L0 910 468 A 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 05-Acc/Start Auth. -- Status: OK 0000 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: OK 0000 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: OK 0000 0E-Media Player 1 -- Status: OK 0000 0F-Digital Radio -- Status: OK 0000 11-Engine II -- Status: Malfunction 0010 31-Engine other -- Status: Malfunction 0010 13-Auto Dist. Reg -- Status: OK 0000 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 1D-Driver Ident. -- Status: OK 0000 1E-Media Player 2 -- Status: OK 0000 28-HVAC, Rear -- Status: OK 0000 34-Level Control -- Status: OK 0000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: OK 0000 38-Roof Electronics -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 53-Parking Brake -- Status: Malfunction 0010 55-Headlight Range -- Status: OK 0000 56-Radio -- Status: OK 0000 57-TV Tuner -- Status: OK 0000 61-Battery Regul. -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 65-Tire Pressure -- Status: OK 0000 67-Voice Control -- Status: OK 0000 6C-Back-up Cam. -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 77-Telephone -- Status: OK 0000 Code:
Fault Codes have been Erased 1 Fault Found: 006435 - Please Check DTC Memory of ECU Number 2 P1923 - 008 - Freeze Frame: Fault Status: 01101000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 148321 km Time Indication: 0 Date: 2018.05.23 Time: 15:13:13 Freeze Frame: RPM: 640 /min Load: 22.3 % Speed: 0.0 km/h Temperature: 102.0°C Temperature: 66.0°C Absolute Pres.: 1010.0 mbar Voltage: 12.954 V Readiness: 0110 1101 Code:
Address 01: 1 Fault Found: 006435 - Please Check DTC Memory of ECU Number 2 P1923 - 008 - Freeze Frame: Fault Status: 01101000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 148321 km Time Indication: 0 Date: 2018.05.23 Time: 15:14:51 Freeze Frame: RPM: 639 /min Load: 20.4 % Speed: 0.0 km/h Temperature: 102.0°C Temperature: 67.0°C Absolute Pres.: 1010.0 mbar Voltage: 13.208 V Address 11: 1 Fault Found: 005491 - Left Engine Mount Solenoid Valve (N144) P1573 - 004 - Open Circuit Freeze Frame: Fault Status: 01100100 Fault Priority: 0 Fault Frequency: 1 Reset counter: 255 Mileage: 148321 km Time Indication: 0 Date: 2018.05.23 Time: 15:14:49 Code:
Fault Codes have been Erased 1 Fault Found: 02596 - Rear Brake Pads Worn 008 - Implausible Signal Freeze Frame: Fault Status: 01111000 Fault Priority: 6 Fault Frequency: 1 Reset counter: 9 Mileage: 133232 km Time Indication: 0 Date: 2015.09.24 Time: 00:02:20 Freeze Frame: Voltage: 10.46 V Count: 61 |
Hi there,
I had 2 of those error codes on my D3 S8, namely engine mounting and ecu code. Neither changed or had an effect for over 100,000 miles. Rear pads easy to check, remove rear wheel and look. Regards Richardracer
The Active engine mounting soloniods are not working on most D3's and most people ignore them due to stupid cost and time consuming job to replace them
That's good news. Will try and get the mount checked to ensure it's not shot and if it's ok leave it alone |
