Old 10th June 2018, 08:27 PM
Default Phone cradle recommendations for a D2?!
Hi all,
Bit of a strange silly one really, but does anyone actually know of a decent phone cradle that squeezes in the only legal place these can be fitted?
Apparently it's the lower right hand side of the windscreen above the dash, where there a multitude of air vents and not much room either!
Old 10th June 2018, 09:39 PM
Brodit 652106, mounts to the centre vents so not on the windscreen at all
Buy here from DSL Developments along with a matching cradle for your phone
Old 10th June 2018, 11:04 PM
Zip's Avatar
Zip Zip is offline
Thumbs up
Seconded...go Brodit. Best ones out there. I have the black steel bracket that slips neatly between the wood trim around the RNS-D and the dash plastic to the left, and the variable size cradle that currently supports my iPhone 7 in an apple leather shell case. Had a number of handset-specific cradles on the same bracket over the last 10 years, including blackberries and Nokia lumias.
Old 10th June 2018, 11:32 PM
Default Steelie..
..like this, less obtrusive than a plastic mount
http://www.niteize.com/product/Steel...-Mount-Kit.asp
Old 11th June 2018, 03:58 AM
I use the Brodit mount which locates on the left of the centre console, primarily because it damages nothing (the clip just locates over the top edge and hooks under the bottom trim edge and you can slide it and tighten as required) and it keeps everything out of the way of all the vents and buttons
ID:	19454   Click image for larger version
Old 11th June 2018, 09:21 AM
Thanks my friends, some great ideas there.
MJ, does that one damage the vents? I'm a bit sceptical of vent ones as I have a Samsung Galaxy S7 and it's a bit of a lump!
Don't want my beautiful vents getting damaged!
