hello all
In almost 18 months of ownership I have only covered aprox 500 mls in my D2 S8. It's been a bit of a resto project. On a couple of occasions, when pulling away at traffic lights, it seems to pull away in second gear. Is this a normal function of the gearbox DSP selecting a smooth set off reflecting my sedate driving style or is this the start of a potential problem. Thanks all in advance |
Does it then operate normally with no clunks? No indication of it being in limp mode? (Such as "PRDNS" illuminated which can sometimes be triggered by selceting reverse for some reason). I would suggest you scan it with VCDS to check if there are any indications there pointing towards a F125 switch problem. My F125 problems started off with a similar issue i.e. incorrect gear selection when pulling away.
Also, take it out for a long, sprightly drive - these cars need to be used!
If my old memory is correct, it's normal after sedate driving if you don't come to a complete stop and accelerate gently for the gearbox to stay in second gear. i think it says this in the owners manual also check your kickdown switch they are almost always turned off.
Dave
2002 S8 silver with black half leather 2000 d2 S8 in Racing green pearl, RS4 manual gearbox, 2003 A4 avant TDi 1997 Volvo V40 2.0T 1992 Mazda eunos v spec 1976 Reliant Kitten 1965 Porsche 911 |
Thanks for the replies everyone.
I have VCDS and there are no reported transmission faults. Car has done this maybe 3 times. There are no clunking noises at all and shifts seem pretty smooth. No fault indicator lights on the transmission indicator. The issue only happens when I am already at a complete stand still, traffic lights etc. The last time this happened was whilst having a fairly steady drive to work some nob pulled along side me at some traffic lights, clearly intending to cut me off as the lanes went from 2 to 1. Car was in drive, I moved lever to tip mode to check what gear was displayed on the dash. According to that we were in first. I put back to drive ready to set off (not sport mode). On setting off it was clear she wanted to take it steady. I was left looking like the guy who took the moral high ground and let the other guy in. On this occasion, I didn't want to be that guy. Push further on the throttle and she changes down and away we go. Car has only done 87000 mls and gearbox oil and strainer have been changed recently. My gut feeling is that this is normal after periods of smooth driving. Also bear in mind that I disconnect the battery quite often whilst working on the car so maybe the car has had no time to learn my driving style. What I was hoping is that you guys would tell me this is normal and you have all experienced this when driving steady. If that's not the case than clearly she is doing something unusual and thus a potential future problem. MAF meter likely to have any influence over this? |
