Haven't used the S8 for a couple of weeks and starting it today got a low coolant warning.
Indeed it was low, and as an emergency measure I topped up with softened water. It took about 750ml to get up to the correct level. ![]() Now I have to confess I haven't checked this in ages, so it could have been low for a while, though I think I would have noticed. So I'll monitor it regularly. But what do I get to put in it now, assuming it will be OK for a while as is? The label says G12, but looking online it appears that G12+, G12++ or G13 supersede that. Where would you recommend going and for what, to top up? I have a VW dealer not far away who ought to have coolant in the parts department. Looking on ECP they recommend TRIPLE QX Antifreeze (Red (Concentrate) Antifreeze/Coolant 1Ltr) Product Code: 523770482, which is only £5/litre. And would you syphon some out of the tank and top up with concentrate?
The usual culprits for coolant escaping are the radiator, oil cooler pipe and heater core bleed screws.
750ml of water isn't a lot in terms of diluting whats in there (10 litres). I'd grab a couple of litres of concentrate from wherever and put that in neat for the next top-up then use the old container to make a 50/50 mix. Any modern red / pink coolant will be compatible. |
Thanks MJ, useful advice.
![]() I'll pop along to my nearest ECP sometime and get a couple of litres of that red stuff then. I'm old enough to remember topping up radiators on almost every journey so losing a pint or so over an unknown period doesn't worry me much! Edit: Can't be bothered to drive to ECP so ordered online using whatever the current discount is; should be here Tuesday and just over £10 for 2 litres delivered isn't bad.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 2nd December 2018 at 04:35 PM. |
I was expecting to need the S8 this evening, but don't now, so fortunately not a problem. ![]()
Cracked coolant expansion pipe where the small hose connects also leads to slow coolant loss and is a common problem, mine has been replaced twice and is cracked once again. Another thing could be valves sticking open in the expansion tank cap so water is slowly evaporating or can be pushed out if car gets too warm (also happened to mine, failed electric fan meant it was getting a bit warm and stuck valves in cap meant coolant was disappearing.)
Mmm good point on the coolant bottle. I forgot about that one.
There's no reason to not drive it as long as the level is correct. That 750ml of water will make no measurable difference to anything since its diluted the coolant by only a few percent. It might freeze at -29 now instead of -30 ![]() |
