Old 18th April 2019, 10:41 AM
Default Discs and Pads
Looking to replace my discs and pads. I usually go with Genuine or Brembo. Any recommendations?
Disc are 345mm front and 269mm rear (2002 FE) ... is that right?
(OE part numbers: 4D0615301E and 4D0615601B respectively I think)
Also, I'd prefer some discs that don't rust so quickly ... Should I be looking for "painted" or "coated"?
And presumably drilled/grooved discs are noisier and provide little benefit (except maybe on the track)?
Old 18th April 2019, 11:22 AM
homer simpson's Avatar
I'm sure Brembo are OEM anyway so I would replace with Brembo rather than pay Audi more money for the same product with a stamp on it
Old 18th April 2019, 11:43 AM
Brembo pads seem to fit the calipers best, and the OE pads are NLA now anyway.
I've used Pagid discs for a long time, but the rears are starting to go rusty on my S8 after only a year which is annoying. If Brembo do a coated version I'd agree to go with those. If not, Textar might be worth a try as they do a coated version and are also an OEM manufacturer.
FL S8 is 280mm rear btw.
Old 18th April 2019, 12:33 PM
Nognar Nognar is offline
I used Brembo discs and pads on my D2 S8 last time from Euro Car Parts.
Working well, though I did have to trim the pads a little as my callipers are a little corroded.
Old 18th April 2019, 01:11 PM
Thanks all
Brembo do seem to do a 'coated' version but I'm struggling to find any in stock anywhere. So I might give Textar a try in that case.
Failing that, Pagid seem to be the most readily available.
Presumably Febi and TRW, which are generally much cheaper, are rubbish?
And what about Ferodo? Any good?
https://www.ebay.co.uk/itm/Ferodo-DD...m/282731326040
(coated rear discs and pads)
And would these fit the front?
https://www.ebay.co.uk/itm/Ferodo-DD...-/282731507463
(345mm x 30mm, 5 hole, but does not specifically list D2 S8)
Old 19th April 2019, 06:21 PM
Funny how our experiences differ. I’ve had Pagid discs go ‘warped’ within a few months and the pads don’t seem to fit quite right.
