i just want to do my own pad change on my cars A8 & A6 so need a simple tool that just opens and closes the calipers..
any recommendations guys please..
Looking for the Holy Grail Audi .. 2018 VW Caravelle Executive T6 2010 A6-C6 3.0tdi LeMans Quattro |
Cheap tools are on ebay around £50. There are a couple of videos on YouTube for manually releasing them (one using a 12v battery) but I'm not sure I would use that method. Is purchasing VCDS not an option? Would be handy seeing you have at least two VAG cars.
2008 (facelift) S8 with B&O, ACC, glass sunroof, reversing camera, front and rear heated seats, ceramic brakes, homelink, electric side and rear blinds, ski load through, heated fan washer jets, remote boot closing, de-flapped manifold, fridge, umbrella holder ![]() |
i have 2 friends with vcds so no probs there
i just want to change pads without bothering them as both are 30 miles away i found this one http://www.ebay.co.uk/itm/VAG-VW-Aud...l/123785210439
You also need a wind-back tool - not one that spins the piston, but one that presses it in. Opening caliper with VCDS doesn't pull the piston in, it just allows it to be pressed in..
You are supposed to undo the bleed nipple first too. If you don't have the wind-in tool, you might get away with prying against the old pads though. |
ive got a wind back tool no probs there
its the electronic open and close bit i need
