Hi folks. My '02 S8 has just gone through the MOT again (spent a freezing weekend in january replacing all 8 front control arms & track rod ends) and just scraped a pass - emissions were only just within tolerances.
My question is this, I have the engine light on, it's been on since I had some sports cats fitted at a place in Sheffield about 6 months ago. VCDS reads the fault as "CAT bank 1 & 2 inefficient" or something along those lines. The MOT guy said the cats were fine - the emissions suggest it's more likely a dodgy oxygen sensor. He has a diagnosis machine that he reckons can pinpoint which sensor is at fault, but I'd like to try and find out for myself (can't afford his hourly rates ![]() Can anyone give me a run-through on how this is done using VCDS, or can you point me to a guide some place? I know there are supposed to be pre- and post- cat sensors, but other than that I'm ignorant to these things so any advice much appreciated. ![]() |
The chances are your sports cats are 100CPI and the downstream LAMBA is picking up out of tolerance readings. There is a post on Audiworld about fitting recessed Lamba holders which will cure the engine management light and stop the sensors throwing codes. Have a google for it. If I come across it I will post.
Hi folks. Well I'm sat here totally at a loss as to how to trace which of these o2 sensors are goosed. Here's my VCDS log:-
Address 01: Engine Labels: 4D0-907-560-AVP.lbl Part No: 4D0 907 559 AA Component: 4.2L V8/5V G 0002 Coding: 10753 Shop #: WSC 02313 4 Faults Found: 16814 - Catalyst System; Bank 2: Efficiency Below Threshold P0430 - 35-00 - - 16804 - Catalyst System; Bank 1: Efficiency Below Threshold P0420 - 35-00 - - 18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal P1639 - 35-10 - - - Intermittent 18047 - Accelerator Position Sensor 1/2 (G79/G185): Implausible Signal P1639 - 35-10 - - - Intermittent Readiness: 0000 0000 Address 03: ABS Brakes Labels: 8D0-907-389.lbl Part No: 4D0 907 389 E Component: ABS/ESP allrad D56 Coding: 08397 Shop #: WSC 02313 1 Fault Found: 01119 - Gear Recognition Signal 35-10 - - - Intermittent Address 17: Instruments Labels: Part No: 4D0 919 035 BA Component: KOMBI+WEGFAHRS.VDO D39 Coding: 00483 Shop #: WSC 02313 No Faults Found or DTCs not supported by controller or a communication error occurred Address 56: Radio Labels: Redir Fail! Part No: 4D0 035 192 M Component: Radio BNO 0001 Coding: 00117 Shop #: WSC 00726 1 Fault Found: 00852 - Loudspeaker(s); Front 36-00 - Open Circuit I checked with the place that did my cats, they haven't sold or fitted 100cel cats for about 6 years due to MOT failures and too many customer complaints. So I'm confident the cats are 200cel. I'm about to delve into VCDS measuring blocks to see if I can suss out which sensors are giving out dodgy readings - anybody know what I should be looking for? I did a trial run earlier and had a look through all the different readings and blocks, so I've an idea where to look now, I just don't know HOW to look and WHAT to look for ![]() I've got Elsa on the go now so I'll report back if I find anything. |
Hmm, well I guess I'll have to delve deeper. Results:-
Group 034: O2S Aging Bank 1 760 /min Engine RPM 650 to 720rpm 365.0°C Exhaust Temp >200 Celsius 0.64 s Time Period 0.1-1.8s B1-S1 OK Diag Status Test/ON/OFF|OK Group 035: O2S Aging Bank 2 760 /min Engine RPM 650 to 720rpm 365.0°C Exhaust Temp >200 Celsius 0.56 s Time Period 0.1-1.8s B2-S1 OK Diag Status Test/ON/OFF|OK Group 036: O2S Beyond TWC [B=Bank S=Sensor] 0.845 V Volt Supply B1S2 0-1V B1-S2 OK Diag Status B1S2 Test/ON/OFF|OK 0.840 V Volt Supply B2S2 0-1V B2-S2 OK Diag Status B2S2 Test/ON/OFF|OK Group 037: Oxygen Sensor Control System Bank 1 15.8 % Engine Load 13.5-22.5% 0.080 V O2S Volt B1 S2 0.1-1.0V 0.0 ms Corr val B1 S1-S2 -200-200ms System OK Diag Status Test/ON/OFF|OK Group 038: Oxygen Sensor Control System Bank 2 15.8 % Engine Load 13.5-22.5% 0.095 V O2S Volt B1 S2 0.1-1.0V 0.0 ms Corr val B1 S1-S2 -200-200ms System OK Diag Status Test/ON/OFF|OK Group 041: Oxygen Sensor Heater Bank 1 @Idle 0.10 kOhm Sensor 1 Resist 0-0.9 KOhm Htg. S1 ON Heater Bf TWC Status 0.20 kOhm Sensor 2 Resist 0-0.9 KOhm Htg. S2 ON Heater Af TWC Status Group 042: Oxygen Sensor Heater Bank 2 @Idle 0.10 kOhm Sensor 1 Resist 0-0.9 KOhm Htg. S1 ON Heater Bf TWC Status 0.10 kOhm Sensor 2 Resist 0-0.9 KOhm Htg. S2 ON Heater Af TWC Status Needless to say, Group 046 test failed again, same inefficient story. Do these values look ok for the O2 sensors? I presume they must be as the tests concluded as ok with VCDS. |
I'm out of my depth here. I'll tip Ben off at AVP see if he will comment.
Got ya PM Mike!
This is a definate issue with the CATS being of a different tolerance to Audi's own. The car will pass an MOT with flying colours even though it won't pass the car's own on-board emissions control checks. The post CAT lambdas sole job is to monitor the condition of the CATS, the pre-CAt ones doing the job of fuel metering. The CATS will jsut be not as good as Audi's original, therefore the only fix I have used in the past has been a mod in the engine ECU map. Usually you only have this issue on tuned cars so a map mod is simple and req'd anyway. The modified map just adjusts the sensitivity of the post CAT lambda's (or removes them if no cats are fitted!!) Hope this helps - don't go spending on new Lambdas!!! You'll be wasting ya cash! ![]() |
