Hi I need to do the timing belt on my 2002 2.8Q
I know that its a good idea to also do the water pump and make sure its rotor is a metal one and not plastic. I will be also replacing the thermostat. The belt kit itself will be INA brand. Is there any thing else I should be looking at? Do any of you know any decent places in Wales to get it done? |
I'd recommend a genuine water pump - they're only £80 or so, and they come with a new gasket.
A genuine thermostat is about £25, although this time doesn't come with the o-ring so don't forget that. You'll need a vacuum coolant filling system to bleed it properly afterwards as the V6 won't bleed itself like the V8 does. |
I'm not taking on any customer work at the moment.
Hopefully someone will be able to make a recommendation in your area though ![]() |
I just had a quote for £1000 to replace the timing belt with thermostat, all the tensioners, aux belt and its tensioner, water pump and the crank seal inc of VAT, do you reckon thats a fair price?
