The 8 went in for its annual MOT today - another pass
![]() ![]() I never normally pay much attention during the MOT test and just let them get on with it, but today when they were doing the brake test I noticed that the rear wheels were not moving when the fronts were on the rollers, and vice versa when the rears were on the rollers. Is this normal? Shouldn’t the other set of wheels not on the rollers try and jump the car forward? I mentioned it to the tester and he said it’s normal. Shouldn't they raise a 4WD car? Surely it’s not good for the transmission?
Usually with four wheel drive cars, the tester will select a mode on the brake tester that rotates the wheels on each axle in opposite directions. This prevents the axle 'winding up' the centre diff and the wheels not in the rollers
Thanks Adrian. I guess they wound up my diff today
![]() Hopefully there’s no long term damage.
My tester used to drive my D2 down the lane to test the brakes as they couldn’t do 4wd on the machine
Proper quattro with a torsen diff is absolutely fine on 2wd brake rollers as the torsen can easily accomodate the small amount of rotation. Haldex though, not so much, as the rear diff clutch would be locked up so it would either destroy the clutch or the diff. That would need the wheels rotating in opposite directions as Adrian described. I've never seen that happen though.
Most MoT testers I know just do a road test, some with a special weight-gyroscope sort of thing to measure the braking force, - my current tester particularly as he had to pay for a new diff on a TT quattro when they first came out! |
Similar to MJ's reply I think.
My tester puts a pendulum type of device in the passenger foot well and then goes for a test drive.
Inertia Tester is recommended by the Ministry for 4 wheel drive if the Test Centre does not have a 4 wheel roller.
