Old 2nd March 2020, 11:43 PM
Audifan Audifan is offline
Default center console bracket
What is this metal bracket for in this picture? I added a red arrow pointing to the bracket.
I'm getting hung up on this bracket for the replacement HVAC foot well panel that I'm trying to install. I don't want to force this panel in and break it.
Name:	side bracket.jpg
Last edited by Audifan; 10th November 2020 at 12:42 AM. Reason: added missing picture as attachment
Old 3rd March 2020, 06:42 AM
It supports the pedal cluster, but it looks in your picture like its been cut where the arrow is, or is that just a trick of the light? It should go from the dash bar down to the side of the tunnel.
Old 3rd March 2020, 05:07 PM
Good question. I have no idea if it has been cut or not. What is the best way to install the HVAC foot well trim panel without damaging it? I want to avoid cutting or bend that bracket.
Old 3rd March 2020, 05:14 PM
It does take a bit of wrangling but there should be enough lateral movement around the pedals to get the centre piece in first, past that bracket, then swing it forward in to the connection going to the foot well vent.
Old 8th March 2020, 09:07 PM
I got around to getting it into place. It was a pain. I had to remove the side panel from the center console
Old 8th March 2020, 09:19 PM
While I was doing this job I noticed that there was a wiring harness that's just hanging out and I'm wondering what this is for? Here is 2 pics of the wiring harness.
I pulled back the cover and its a connector of some sort.
What is this for?
Since I got the HVAC foot well panel installed and noticed the panel insulation is pressed up against the clutch pedal arm. It's kinda hard to see in the pic below. I have a feeling that I need to cut this out as it's in the way?
ID:	24415   Click image for larger version
ID:	24416   Click image for larger version
Last edited by Audifan; 9th November 2020 at 10:35 PM. Reason: switched pictures to attachment
