I know I'm getting ahead of myself as I have other maintenance that needs to be done on my car but I don't care. I want to upgrade the brakes on my car and wondering if anyone installed 17z front calipers and Boxster (1st gen) calipers for the rear on the FL S8?
6-piston calipers with no provision for handbrake, on the rear?
Not 6-piston calipers for the rear. I'm looking to do 6-piston (17z) calipers for the fronts and 4-piston calipers for the rear. This guy uses a custom hydraulic e-brake setup for his rear 4-piston calipers
oh gotcha
![]() A hydraulic handbrake is not allowed for road use here. We have to have something mechanical. Aren't the 17z discs smaller than the stock FL S8 fronts though? 330mm I think, compared to the S8's 345mm. People seem to use a 345mm Mercedes ML disc with the 18z too so also no bigger. I have attempted to figure out fitting an 18z caliper to a 365mm RS4 front disc, but could see no way for it to work as the mounting lugs for the caliper and upright both occupy the same place, so I'm keen to see what you come up with. It would be much easier with radial mount calipers. That said, it might be possible with the ML disc. Just no upgrade in size, although the Porsche monoblock calipers appear superior to the S8 Brembos in pretty much every way. It springs to mind actually that I don't think I've tried the 18z caliper with a stock S8 disc. Hmm... |
It's ok, no worries.
Bummer to hear. The other option is try and custom fit these for mechanical setup. Yes they list the 17z calipers to use 330mm discs and 18z calipers to use 345mm discs but I'm sure you can use larger discs for either calipers. After some searching this guy is using 350 mm discs with 17z calipers I did some more searching and found that the C5 RS6 and B7 RS4 use 8-piston calipers and 365mm discs. So I guess the other option is to try and fit 8-piston calipers for the front and use 365mm discs. Will these fit with 18" wheels? |
I've done B7 RS4 brakes on a D2. Thats easy as they are radial mount calipers the same as the D2 Brembos so the adapter is a 10mm thick flat plate with 4 holes in it. I would expect they fit in some 18s as thats what the B7 had stock, although the RS6 had 19s.
The 18z will fit over a 365mm disc no problem - it just needs a litle grinding at the outer edges. But, the mounting lugs then occupy the same place in space as the lugs on the upright so you can't even put the caliper on the disc, let alone contrive an adapter. I'll get a pic tomorrow - its a vexing problem since those calipers are cheap and easily available. |
