MOT failure
Sadly my S8 failed yesterday, but nothing serious - rear brake pads excessively worn.
The local garage that does the MOT seemed confident they could source and replace them easily enough so it's booked in for Thursday for them to change the pads and retest. It's a typical local "all-cars" workshop with a good reputation. Anything specific I should warn them about when changing the rear brake pads, something I would assume is pretty quick and easy? As an aside they had a single advisory (Monitor and repair if necessary) which I found a bit odd - Rear axle corroding. I might ask them to explain that a bit when I go back given there is no such thing....
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (Even rarer than a D2 S8!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! |
They probably mean the rear subframe, which is pretty common. Unfortunately its a big chunk of work to remove it and re-paint.
Rear brake pads are the same as on anything else of that age and very simple to do, as long as the discs are in decent condition. Its worth being aware that they may find problems with the seals on the rear calipers as they fail often, especially when fully extended due to worn pads. |
Turned out worse than seals, the offside piston(s) is/are seized and won't push back, which is probably why I had a wear problem in the first place.
The nearside caliper was replaced anyway a while back, so it's a new offside one now to match as apparently they're still readily available.
The calipers might be available, but the garages suppliers struggled to send the right ones, took them a couple of goes.
Got it back eventually today, freshly MOT'ed as well. They did clarify that advisory was indeed for the rear subframe and it was only surface corrosion. Not sure how much labour it was as there's no stated hourly rate, but that was £90 plus VAT. The parts, especially the caliper, were more than that as expected, though the pads (Pagid) weren't a lot.
Congratulations Good to hear your car passed the MOT.
My car failed the MOT as well, rear caliper piston seized and rusty. Still working on mine, as I discovered several issues.
Johannes _________ Audi S8 -99, Pearlescent, Alcantara/silk napa leather, Burr walnut insert, Alcantara roof lining upper pack A8 32V engine ----- Jeep Grand Cherokee -98 |
Rear callipers always give me cause for concern (or I just don't have much luck with them!). Have had replacements where the adjustment bering inside was garbage and they fail quickly. Worth keeping an eye on them. I sometimes fire a temp sensor on each of my disks after a spin just to check that the callipers are all reasonably even and working as they should.
Retro Audi fan! A2 1.6 FSI, Audi Cabrio v6, D2 S8. |
But I need the car urgently so I had it MOT'd again yesterday after a few checks and a quick spin to clean up the brakes. Only drawback was that the handbrake needed a serious pull to get it to pass, but it did - just. Apart from that, and a note of an oil leak, no problems despite having sat outside unused for most of the last 2 years! Not bad for an (almost) 20 year old car. That anniversary arrives soon, it's build date is 24th April 2002. Hopefully, if all goes to plan, by that (China!) anniversary it will be in pieces - being expertly fettled by the D2 Doctor!
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". (Even rarer than a D2 S8!) Oh, and a brand new engine at just under 30,000 miles on the factory one! Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. (internal dimming mirror added later) 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 15th February 2022 at 07:01 PM. |
Good to hear that you got it passed the MoT Andrew
No doubt the handbrake adjustment will be on the Doctors list now!
