Old 14th August 2020, 08:00 PM
craig's Avatar
craig craig is offline
Default Gearbox help
https://photos.app.goo.gl/Mn2Q5fRhAb8GvSpn9
Old 14th August 2020, 08:12 PM
F125 switch fault is the first thing that springs to mind.
Does the car start and drive? Can you get the key out?
Old 15th August 2020, 01:25 AM
craig's Avatar
Key works as normal goes in turns on and cranks if I leave key and try to take it out in any other position other than park it won't come out as normal.. I get my parking sensors when in reverse working as normal as the back end is up against the garage wall I can turn it over in park do you know difference between oval black plug on f125 switch and the round plug as in the extra pins and what they are for doing my gearbox swap the have diff pugs I've used the plug from gearbox that happened to go bad as for the gearbox I put in it has oval plug but because of engine wiring loom had to use round plug.. I've got the loom from other car that the reconditioned gearbox came from at cost of 2600 quid so rebuild but what would I be missing as connector has 10 pin as apposed to 8 on round plug
Old 15th August 2020, 01:42 AM
craig's Avatar
http://forum.a8parts.co.uk/album.php...pictureid=1407
Old 15th August 2020, 01:43 AM
craig's Avatar
http://forum.a8parts.co.uk/album.php...pictureid=1378 what is the difference
Old 15th August 2020, 07:56 AM
The differences between the two versions of the switch are almost certainly the cause.
We'd need to know more about the age and details of your car and the car where the gearbox came from to comment further.
Also did you keep the F125 switch from your car and just move it to the new gearbox or graft on the other plug?
From your brief description above it's not at all clear what you did re the F125 switch and connections when swapping the gearbox, maybe describe it step by step so it's obvious.
How to rectify it, if you can, needs someone with an intimate knowledge of the interior and workings of the F125 switch.....
Now who might that be?
