Making progress with the electrical gremlins thanks to smart a8parts folks (fixed my gps antenna, etc). Last thing I'm chasing is the "doors open". Took the latch out of the PF door and was looking and checked the switch, which is good. I have the door window carrier out, and the switch only, connected to the wiring, in my hand. I found that if I manually close the switch, it will probably show all doors except the drivers door as open. But, if I rock just a little in the drivers seat it will make the door indicator read as those three doors closed unless I let go of the switch. Wiring looks fine back in the hinge area, etc. Could this be some leveling sensor or something? Going to go drive the car and see how it acts. Any thoughts appreciated. Yeah, went for drive and all doors but drivers door are intermittent open/closed at the same time... all controlled by the frnt pass door switch?
Does it have or has it had aftermarket alarm. OEM are each door switch on separate wiring but many aftermarket only have 1 or 2 inputs for door open switch so the wires get connected together. This should be done via diodes to isolate but if done with just a straight connection or if diodes have gone short circuit it will show all/ several doors open.
Not that I'm aware of, had the same old "horn" sounding alarm but the alarm recently has quit... alarming. It has a "parrot" hands-free module tied into the radio? Is clear tho, three doors seem to be tied into the FP door, not sure if the rear doors register independantly or not, will check. This issue might be a bit beyond my ken. |
Are the interior lights working? The passenger front door and two rear doors have a separate power supply to the driver's door hence why when there is a fault in the system it shows one door, or three. The interior lights are all tied in to this system.
I think, that all interior lights are working except the auto-on function of the overhead light. I'm going to wiggle some wires and have someone watch the indicator, beyond that I'm willing to remove the seats if there's any connectors that could be bad, or anything else that's easy enough to get access to, can't see myself pulling the car apart for this tho... hoping for something that doesn't require that. Surely this has something to do with the fact that first thing I did when I got the car is wash it- with badly clogged drains.
Little update. I checked the wiring, wiggled everything with someone watching, it does not affect the issue. However, I found that actually shaking the car *might make the lights go out but rocking in the drivers seat will more reliably, make the lights go out. Then I played with the seat position, raising it a little made them go out solid (and come on) as they should. I think some connector or whatever thing under the d. seat is doing this... sound right? Thanks
