Old 29th October 2020, 08:49 PM
Default Autobox peculiarities
Just realised that my car has previously featured on here while belonging to Audidoody, whom it seems I bought it from.......
Anyhow, just trying to determine whether this is a fault or a feature.
I'm not an autobox connoisseur, I've owned 3 in 35 years of driving - a Dolomite Sprint that got converter to manual pronto as it was such an awful combination (BW65 3 speed clockwork slushbox that insists on changing up at 3.5k and an engine that comes on cam at 4k....) and my previous A8 - early 4.2 with the 4HP22 - which was ok, but not very subtle.
This one 2.8 FL 2WD is more subtle, but has some quirks.
1.
It's really quite hard to make a smooth getaway. It either just creeps away, or if you apply a whisker more throttle, suddenly sets off a bit harder than intended - doesn't appear to be a middle way. Not even sure if its a gearbox or throttle thing.
2.
when pottering about in traffic, it fusses about, changing gear more often than seems necessary. It's quite subtle about it and the changes themselves are fine, just seems a bit unnecessary. And sometimes, when you apply a little extra throttle it changes up a gear.
3.
It appears to alter it's behaviour and is not consistent with it's change points. Possibly it's tracking my driving and adjusting, but I don't think it does it very well. In tiptronic mode it's lovely and the changes seem even smoother - which also makes me wonder about the throttle.
The invoices say it had an oil change in 2015 ans the PO told me it had a new throttle body quite recently (also mentioned on here).
Could be it's entirely normal - a feature rather than a fault?
What thinks the panel?
Thanks
Nick
Old 29th October 2020, 10:27 PM
Couple things to check:
1. Brake light switch
2. MAF
3. Vacuum leaks which could affect MAF reading.
Old 30th October 2020, 06:49 AM
Sounds like stock 2.8 programming to me. Big Red's drives me nuts so I just keep it in S all the time.
Old 31st October 2020, 08:22 AM
Can you not change the TCU programming with VCDS? I have done this on my S8 so is it not a feature on the 2.8s also?
Old 31st October 2020, 11:54 AM
Tell me more.... With 4 VAG cars on the drive, two of them distinctly needy, I may have to invest in the full version of VCDS....
Nick
Old 31st October 2020, 01:00 PM
Nick
See this thread http://forum.a8parts.co.uk/showthread.php?t=630
There are some useful links on that thread
Old 31st October 2020, 12:05 PM
Only DSP on/off and tip buttons in D on/off. You can't change the shift points or target rpm range (as far as I know).
Old 31st October 2020, 11:52 AM
Yeah, suspected this might be the case. I'll get used to it. Probably.
On a slightly related note I had and almost new Zafira rental in Spain a couple of years ago (I actually rented a Corsa because I'm cheap, but it broke and I was "upgraded"). This had a 1.4 engine and autobox with tiptronic. Oh joy I thought, how is this unwieldy underpowered behemoth an upgrade....?
The engine was actually better than expected, but the gearbox was just woeful. It's changing habits were so erratic I presume it was broken and the tiptronic was no help as it tended to deny you gears that were perfectly reasonable, even necessary, and then immediately select them if you returned to auto mode. Hateful thing.
Nick
