Old 17th November 2020, 05:26 PM
Ronin Ronin is offline
Default Have any of you retrofitted double pane windows?
If so how much of a difference did it make? What were your experiences?
I'm one of those people that always think the car is too noisy on the inside and I'm always trying to find ways to make it quieter haha.
Old 17th November 2020, 06:02 PM
That's what the Bose is for
Old 17th November 2020, 06:23 PM
RICKY D's Avatar
RICKY D RICKY D is offline
Sorry I can’t answer your question, but I’m of the opinion that it would be an excellent upgrade.
My S8 has them but it’s off the road at the moment (long story) and I’m convinced the cabin is one of the quietest cars I’ve owned.....even compared to much newer stuff.
Maybe it’s all in my head but the S8 to me seems to be so well insulated from outside noise it’s remarkable. I’m either running around in my wife’s smart car or my beater A6 which are both newer and much noisier without the radio on.
Old 17th November 2020, 06:37 PM
Yes, my first ‘8 was a 2.8 Sport Quattro and Prestige/A8 Parts retrofitted appropriately tinted double-paned windows. And yes, you could really notice the difference!
Old 17th November 2020, 06:52 PM
There's a noticeable difference in cabin noise between Big Red and my S8. If I keep her it'll be one of the essential upgrades. All you need is the glass and the channel in the door frame. The rest is the same.
Old 17th November 2020, 07:03 PM
And some door trim clips and the knowledge and ability to take it all apart and reassemble correctly.
Though having swapped a whole upper door frame (broken pulley!) and moved the glass over in the process it can't be that difficult if I did it.
(Just missed a trick with that damned triangular trim behind the rear window though)
Old 8th September 2021, 06:58 AM
Alcantara headlining......
It soaks up some road noise for sure. +1 for twin pane windows making a difference. Also, larger profile tyres.
The PF carpets were thicker, making for more sound proofing but given the different colour scheme pre/post facelift that's a bit of a non starter.
But I guess arguably, one of the quietest factory D2's out there would be a Prefacelift S8 with the full enhanced leather pack.......
Old 10th September 2021, 02:44 PM
Does anyone know a decent conditioner for the door seals etc? I want to clean and treat it all properly before it goes into the car.
Do any of you have experience with tinting D2 windows? there are guides on the actual glass that from what I can see will have to be removed, so im probably beter off removing all the windows and giving them to the tinter instead of them doing it on the car?
Old 10th September 2021, 06:16 PM
Spanker's Avatar
Spanker Spanker is offline
For the rubber seals I've used Sonax Gummi-Pflege and Nextzett Gummi-Pflege and I've been satisfied with both.
If you just do a search on eBay for "gummipflege" you should see some appear in the search results.
I don't see it as a cleaner but more of a conditioner. Just rub it in and let it dry.
Dean
Old 10th September 2021, 06:31 PM
I use Autoglym rubber care which is also a conditioner as Dean described. For door seals I spray it on a microfibre and apply it that way so it doesn't get on trim or paintwork.
I would be strongly disinclined to try and remove the glass from the frame. I did this recently and it is very tricky to get back in. It also comes with a high risk of breaking the glass if you tweak the pins the window runs on. Any competent tinter should be able to do it in the frame. The pins are in the masked area of the glass anyway.
