D3 - Fuel and Exhausts Everything to do with getting fuel into the engine, and fumes back out again |
well guys been on here a bit now and only just found this section
so i am getting used to the power of my car now and i want more already.... so im open to ideas , as far as i know its a std car, reading a few threads tell me i may have less power due to carbon on the inlets and flaps, an should have it cleand and the flaps removed. i am in kent and would like to know if there is any recomendations where or if i should get this done . as its somthing that i cannot phyiclys see being done, any thought greatfully welcome thanks ![]() |
I think the closest place to you is AMD Essex. There may be others but they have done other cars before and so know what they are doing.
VRS in Northampton also do this, if you fancy a trip.
2008 (facelift) S8 with B&O, ACC, glass sunroof, reversing camera, front and rear heated seats, ceramic brakes, homelink, electric side and rear blinds, ski load through, heated fan washer jets, remote boot closing, de-flapped manifold, fridge, umbrella holder ![]() |
thanks i will look them up
need to send of for me passport to get into essex though ![]() |
If not so inclined - consider the expanded scope above as my oil filter housing was leaking, and all my injectors were not squirting properly and I actually ended up replacing 4 and rebuilt 6. Good luck!
Present cars Daily driver: BMW e65 730d Batmobile: 2006 S8, D3, 4E 5.2L V10 BSM with (loud) Miltek SS exhaust, Carbon Fibre trim, Alcantara headlining, soft close and keyless entry. ![]() |
