D3 - Body and Exterior Bumpers, bonnets, glass, trims - Everything outside |
Bit of a noob question as learning the foibles of the D3....
Is it normal when operating the windscreen wash, the headlight washer system activates one side at a time??? I get the drivers side pop out and spray water, then once that’s done it’s spray it retracts and then the passenger side activates. My previous Audi’s have always done both headlight washers at the same time.... |
Yes, but design. Only affects the output of one headlight at a time
Well everyday is a school day.... how weird but at least it’s not broke
Makes perfect sense, only need half the power from pump and only affects light output from one light at the time.
The time delay and washer time duration can all be altered in the adaptation channels.
Do you know if you can alter the washer timing? As the spray from my headlight washers inevitably tends to find its way onto the windscreen, and need a manually activated pass or two from the wipers. (first world problem I know)
2010 A8 SE Executive 4.2 FSI D4 2007 Mini Cooper S R56 2008 D3, gone, but not forgotten after 9 years and 90k. |
