Hi all I've order a vagcom ( Ross tech) ,and would like a car manual that includes vagcom info to allow me to identify/ check and clear faults etc or alternatively 2 separate manuals , and was wonder which is best and were to get .for s8 d3
With Bang & Olufsen Advanced Sound System, Advanced Parking System, TV Analog/ Digital, Rear/Back Window blinds, Front and rear heated seats, Alcantara Roof, Extended leather Pack 2, Extended Aluminium pack, Carbon and Aluminium trim packs, RSE, PS2. Daily driver Audi A8 d4 2014 phantom black 3.0 tdi Previously owned Audi 80 1986 1.8 white Audi 80 1990 2.0 red Audi A4 1996 1.9 tdi green Audi A6 1.9 tdi 2000 blue Audi tt 225 2000 silver Audi s8 d2 2002 fe grey Audi a8 4.0 tdi d3 2006 black Audi a8 3.0 tdi d3 2010 black |
Best place to start is the Ross Tech Wiki pages. They also have a forum for registered users. VCDS is very user friendly and generally won't let you do anything major without prompting you.
The checking for fault codes (scan) is easy as you just click on 'Auto Scan' and it will scan every module in the car. Any faults will show in red and you can then click on them to see what the code is. If you want to just interrogate one module, you can select it manually. http://wiki.ross-tech.com/wiki/index.php/Main_Page
2008 (facelift) S8 with B&O, ACC, glass sunroof, reversing camera, front and rear heated seats, ceramic brakes, homelink, electric side and rear blinds, ski load through, heated fan washer jets, remote boot closing, de-flapped manifold, fridge, umbrella holder ![]() |
As far as I can tell VAG Com works the same on my D4 as it did on the D3.
Like Home said, it's user friendly and you will be able to easily figure how to clear fault codes. For making changes to settings, I use the net and dig about.
Spot on Nick. My experience tallies with you.
Thanks guys ,I had thought it was more complex ,i don't intend to change settings unnecessarily just to clear and reset faults after the winter maintenance is complete,as a matter of interest I changed rear pads and discs there and refurbed Calipers ,do i need to use vcds to reset values or will hand brake auto learn it's self ,i tried handbrake when finished and it went on and off without problem or faults coming up ( went for short test drive and all good ,wheels weren't binding)
Did you measure the pad thickness to enter through vcds YouTube is your friend.
