Go Back   A8 Parts Forum > A8 D4 > D4 - Sat Nav, ICE, Audio & TV
D4 - Sat Nav, ICE, Audio & TV All in car entertainment discussions including MMI 3G Plus
Old 15th January 2021, 02:50 PM
darrenjoe90's Avatar
Default Telephone Text Messaging
Can anyone help with this small problem that i have ( no not that one ) When using my phone in the car my text messaging is just greyed out and messages are not displayed on my screen. I am using an Android phone and have just tried my sons Iphone and that does the same. Is this feature supposed to work ?
Audi S8 Phantom Black
Old 15th January 2021, 05:03 PM
It'll be greyout if you are using the standard bluetooth audio/handset to the phone (most common)
For it to work, you'll need to have a sim in the dash so the car is the phone, or you will need to use rSAP to connect your Sim from your phone to the car, so again, the car becomes the phone.....
rSAP works on a handful of androids, most Samsungs notably, but no iPhones...
Old 17th January 2021, 01:38 PM
So just tried my other son's Samsung S20 and it did strange things to his phone but as far as i can tell it will work in my car. I just need to upgrade from my OnePlus5 to a newer phone that supports Rsap
Old 18th January 2021, 12:06 PM
When you connect a phone via rsap, the phone effectively gives its SIM to the car, so the phone no longer has an outside world connection.
To make it seamless, you then setup the wifi hotspot on the car, which shares out the data from the SIM contract, and you connect the phone to the wifi hotspot (along with any other devices you fancy).
The phone then accesses its normal stuff over wifi, including calls if it has wifi calling.
As a bonus, the phone is now using the cars external aerial, so the data signal it now gets over wifi is stronger than the connection it could have manged all on its own....
Old 18th January 2021, 04:32 PM
If you've a dual-sim phone like the oneplus, then it will be unlikely to support rSAP
Old 18th January 2021, 06:20 PM
So if this is the case then there would be no need for the data sim that i have in the car as each time i drive it would be using the phone data for online traffic updates and also use the phone as a Wi-Fi access point ?
This has now become an expensive upgrade as i have just ordered a Samsung S21 Ultra !!!
Old 19th January 2021, 04:05 PM
Correct.
