Old 19th March 2010, 09:53 PM
Default Faulty flap motor clicking behind dash
The HVAC system has a number of small servos, all worm driven with tiny motors that are used to open/close all number of flaps to make air go (or not go) where you want.
There is a common problem on the facelift cars where one of the flap motors fails and either sits there endlessly buzzing, clicking, whiring or generally carrying on when it doesnt need to. If you've got odd repetitive noises coming from behind the dash, this could be your problem.
Interestingly, in every case I've seen its always been the same flap motor, this one:
You dont need the glovebox out to get to it, I just happened to have mine out still. You just need the transmission tunnel cover off, which is 1 screw and some cautious manouvering....
The motor is held in by 2 small cross head screws and comes straight off very easily. If you're uncertain if it is the item making noise, unplug the yellow connector on it and see if the noise stops first. Simple as that....
I've just changed one on mine as it was really annoying and inexcusable not to fit it whilst the car was in bits
Old 19th July 2011, 10:43 AM
anxious4.2newbie anxious4.2newbie is offline
Default climate control lights flashing
On my 97, it sounds like the clicking is coming from below the steering wheel (in the dash) and is accompanied by all of the lights on the climate control flickering. Is this likely the same problem?
Old 19th July 2011, 12:36 PM
Very different problem... Are there any relays for climate control down there? Cant quite remember what's hidden under the dash.
Old 26th July 2011, 12:55 PM
skl63 skl63 is offline
Default Part number or name please?
Does anyone have a part number for this flap motor please?
Old 8th March 2012, 09:06 AM
plankton plankton is offline
Is it this one "4D0 820 511"?
Ressurecting this old thread as mine makes this noise too. On mine it seems to be coming from the climate control unit - if I change settings on it (from screen to Auto) the clicking goes away for a bit. Hopefully it's the same thing as this looks a cheap fix...
Kev
1999 4.2 V8
2008 Saab 9-5 TiD Estate 185BHP - long gone. The Merc E250 that replaced it has gone too.
