Old 5th May 2021, 10:29 AM
Default Rear subframe refurb
A few of us have been working on finding parts for the rear subframe and control arms, and I have found one of the missing links - the subframe bushes themselves. The D2 bush is NLA, but the D3 bush fits perfectly
Made a press tool to fit them
These are Lemforder 27312 01, about £21 each. You can see where the Audi rings and part number have been ground off them
I'll update this thread as I go along with the exact part numbers used so we have a concise reference for what is needed. All I'm missing at the moment is the diff carrier bushes but I'm looking in to modifying the D2 carrier to take the D3 bushes.
Oh, and there's no source for the rear upper arm bushes, but since they don't seem to ever wear I'm not too bothered about those.
Parts list:
Main subframe bush - 4E0505145A, Lemforder 27312 01
Diff yoke bush - 4B3599257A, Febi 103 184, Lemforder 26622 01 ***needs machining***
Diff forward bush - 8E0599381B OE only
ID:	26322   Click image for larger version
ID:	26323   Click image for larger version
ID:	26324   Click image for larger version
Old 5th May 2021, 11:12 AM
Can I plan a trip to Devon now please?
Old 5th May 2021, 11:42 AM
Very good news
Old 5th May 2021, 02:21 PM
Perfect, very well done MJ
Audi S8 D2 2002 88k mls
Old 5th May 2021, 05:23 PM
Ronin Ronin is offline
Excellent job on the bushes. Better than poly crap from Poland.
Are these the diff mounts you are referring to:
https://audi-v8.pl//lapa-poduszka-mo...cjalu-p-6.html
Old 5th May 2021, 06:25 PM
Great news and good effort all round What led t you yo try the D3 bushes?
Old 6th May 2021, 02:00 PM
Stromaluski's Avatar
These are Lemforder 27312, about £21 each. You can see where the Audi rings and part number have been ground off them
Small update here. Googling Lemforder 27312 didn't really give me any decent results. If I googled Lemforder 2731201, though, I was able to find the bushing mentioned.
-Andrew
1967 Bus
1980 Rabbit Pickup
1992 Corrado
2001 S8
2010 Jetta TDI Cup Edition
Old 6th May 2021, 02:46 PM
Updated the original post thanks
Old 10th May 2021, 08:50 PM
So I did indeed mill down the rear diff mount yoke 2mm off each side makes it the same size as the D3 yoke
D3 mounts now fit perfectly Happy to do these on exchange with or without bushings if anyone else wants one, since its not really a DIY task.
These are Febi, and as usual you can see where the Audi rings have been ground off post-production. Its actually an A6 part rather than unique to the D3 so easily available for £12 each.
For reference, D3 forward diff bushing on the left, D2 original on the right. This is D3-specific and I couldn't find any aftermarket version, but its only £25 from TPS.
I can't fit this yet as I need to make a new press tool for it.
ID:	26365   Click image for larger version
ID:	26366   Click image for larger version
ID:	26367   Click image for larger version
ID:	26368   Click image for larger version
ID:	26369   Click image for larger version
Old 13th May 2021, 10:10 AM
This is excellent R&D, well in time for my rear subframe refurb .
As far as the suspension gemotery adjustment bolts, we can just use A6 ones correct?
And also is there a list of D2 services you offer, especially the exchange stuff?
Do you do anythig with AC/PS hoses etc?
