Old 14th June 2021, 09:39 AM
quattronutter quattronutter is offline
Default No ignition
2008 d3 no ignition unless i short battery positive several times....on hols with no vcds so cant scan it! Swapped over a spare batt reg module which i had in boot,kessy recently replaced so not that.....any ideas?
Old 14th June 2021, 04:03 PM
Also no central locking until batt lead is shorted on terminal a few times which then wakes it up...starts and runs fine until its left a while,then all dead apart from radio and climate,swapped in a spare main power relay under drivers dash but no joy...
Old 16th June 2021, 08:51 AM
Could you clarify what you mean by "short battery positive"
And "batt lead is shorted on terminal a few times"
Old 16th June 2021, 09:07 AM
If you tap battery pos lead on pos post several times it wakes up...can gateway?....
Old 16th June 2021, 01:31 PM
Try removing the +ve connector, cleaning the post and inside the connector, smear a little vaselinbe on the post and reconnect. Make sure that it is tight.
It sounds like a loose battery connection.
Old 16th June 2021, 01:44 PM
Batt is new and terminal is clean and greased!
