Old 21st March 2010, 02:20 PM
Default WIFI networking advice wanted
Any geeks or nerds (not even remotely dorkish) out there can help me with a project please?
I am now living in a mess without internet. I have offered to build a WIFI net for them as the have internet connection to a single PC. My idea is to place 3 WIFI stations at each corner of the building so that their footprints overlap giving complete coverage. I have set up a wifi router at the PC and its footprint reaches only 40 mtres. So i'm thinking 3 WIFI stations, one handling DHCP and wired together to the internet connection. Is it feasible?
CtL
Old 21st March 2010, 03:03 PM
Yep...
If it's in Rosyth, then I can maybe pop over and help you get it set up.
Ideally what you want are access points rather than routers (though it can be done with these too and probably cheaper).
You want to make sure that they don't have the same frequency channel. Ideally, you want to use 1, 6 and 11 though with 4 points you'll end up with an overlap, just make it two diagonally opposite units and that won't be so bad.
Old 22nd March 2010, 02:55 PM
It is indeed in Rosyth, and thanks for the offer Richard. I may take you up on it!
I'm going to go with base stations on different freqs as they are cheaper than range extenders and I will need less if they are wired together.
Old 22nd March 2010, 03:45 PM
We can still do it that way... Just don't need to use the routing functionality and have the ethernet connection to the centre in one of the LAN ports.
Just make sure that they give out a different IP range for DHCP (batches of 50 should be OK), the same SSID and encryption.
Old 22nd March 2010, 06:03 PM
gninnam gninnam is offline
Another option is to use 'ethernet over power' to feed the different areas then connect these to the WiFi router - give you an even better spread and signal strength too (use this in my 3 story house and it works a treat
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 23rd March 2010, 06:24 AM
There's a thought. I'll have to do some research.
