Since I bought new valve spring kits for my car, I need to know is it necessary to buy these valve stem seals and these valve stem guides? Or just buy OEM seals and guides?
2001 S8 (build date March 16th 2001) Brilliant black with oxblood red/black interior. Mods prior to my ownership: 01E 6 speed, carbon fiber trim, bi-xenon, aftermarket muffler with x-pipe, tinted windows, non-tip steering wheel, Spal electric fan. My mods: Oxblood red interior, LED interior lights, D3 ignition coils, new window tint, tip steering wheel with new S8 emblem, mk1 TT steering wheel air bag, mk1 TT 6 speed shift knob, new shift boot. |
I'd be careful with the guides - 1.8T parts may not necessarily work in the V8 as it has roller cam followers and longer valves iirc.
Given that the original stem seals are still working in most engines after 20 years I would just use OEM or equivalent for those - Victor Reinz and / or Elring make them I think. They are used in lots of other models so easy enough to get. |
I didn't know that about the guides. Good thing I asked about that before ordering them. Do you have the part numbers for the OEM seals and guides?
The guides aren't listed as a separate part but the stem seals are 036109675A.
That's a bummer about the guides.
Thanks for the part number on the seals. Holy crap around $10 for one OEM seal? Is this part number for the intake valves or exhaust valves? Or are these the same for both valves? Also in my search with this part number there are different colors for the seals? Why is that?
I did a little more searching and found these valve guides
