Hi guys,
Today a warning for rear right light popped up on a dashboard and after that I've noticed rear turning signal to be blinking way quicker than normal. Is there anybody who tried to repair D3 facelift rear lights and is it even possible to do that? I'm quite handy with welding and small electronics and would definitely like to give it a go. Thanks, Marko
Audi A8 D3 4.2tdi 2008, 280.000km |
If you are comfortable I would give it a try. I was able to fix my pre-facelift D3 tails using a spare circuit board that I located in a junk yard. The only part you have to be careful about is separating the cover from the taillight housing. It is glued and and can break at any point. Mine didn't take any effort at all, it opened after pulling it slightly. Facelift tails are very similar with very different layout inside.
2015 A8L TDI 2014 Q7 TFSI 2014 A8L TDI sport 2013 A8L TFSI 2008 A8L 2007 A8 sport Used to own: 2000 S4, 1990 90 quattro |
ive never known the rear facelift ones fail b4 suppose theres always a first time
Looking for the Holy Grail Audi .. 2018 VW Caravelle Executive T6 2010 A6-C6 3.0tdi LeMans Quattro |
Strange the whole unit has failed at the same time as you would expect the indicators to still work if the others/brake light failed. Have you tried swapping over the left and the right to see if it works? Could be a wiring issue.
2008 (facelift) S8 with B&O, ACC, glass sunroof, reversing camera, front and rear heated seats, ceramic brakes, homelink, electric side and rear blinds, ski load through, heated fan washer jets, remote boot closing, de-flapped manifold, fridge, umbrella holder ![]() |
It seems it was a one time thing due to heavy rain and probably some water coming in. Now everything works fine.
I can see that one LED in the inner rear light stopped to work and it has a crack just above the reverse light. I'm wondering if this crack can be fixed somehow?
For the crack the best would probably low viscosity UV resin like used in windscreen chip repair. They come in different viscosities. Depends how long the crack has been there, if a long time then there is likely some dirt in 5here so not sure how well it would seal up.
