Afternoon all,
Working on the car today and thought I would take a look at an oil leak that's been getting worse. Not driven the car much but it looks like I have a leak at the back of the engine, missing the under tray and dripping onto the ground. Its stopping the sub frame getting too rusty I suppose! Time to clean it all off and have a look where its coming from. Not sure if its gearbox but it looks like it or something at the back of the engine that's flowing down to there.
-- 2001 Audi A2 1.4 SE - Jaipur Red Pearl -- Last edited by Nognar; 13th May 2022 at 03:15 PM. |
That looks like the left hand output flange - a very common spot for leaks. Can you identify gear oil by smell? Engine oil is not unpleasant, slightly petroly smell. By comparison, gear oil is a vile pungent stench which gets in your nose for hours. ATF is a bit fishy.
The usual culprit for engine oil leaks down the back is the valley gasket. It fills the V with oil which then dribbles out of a vent hole at the back of the bellhousing, down behind the flexplate and out of the bottom. |
