Old 27th April 2010, 11:52 AM
Mr K Mr K is offline
Default (O) on my dash, what does it mean?!
Having successfully changed my suspension arms i now have the yellow (O) on my DIS.
This can be thrown up by ABS sensors, worn pads, and low fluid i think.
I have tried cleaning the ABS sensor on the wheel i did the arms on, but it still comes up intermittently. if it was the sensor i would be expecting to see it come up instantly on startup, but its intermittent.
pads have plenty of meat, the ABS works, brakes feel fine, and it has fluid.
Any ideas whats causing it? is it finally time to invest in a vag com lead and run a scan?
Nick
Old 27th April 2010, 11:54 AM
The yellow (O) is one of the few errors where Vagcom is of no help whatsoever....
Its nothing to do with ABS either, its just your brake pad warning.
This is a simple single loop of wire that runs through both front pads and back to the cluster. Break the loop, the warning comes on....
More than likely you just disturbed it when working at the front end, There are 2 wires connected to the front pads. Sort this out, the light will go out...
Old 27th April 2010, 12:03 PM
I get mine flash up sometimes from a dodgy connection it's the horible Audi BEEP you have a problem, i hate that noise.
BEEP your brake pads, BEEP low fuel warning BEEEEEEP you're going too fast.
Old 27th April 2010, 12:11 PM
You can never go too fast...
Old 27th April 2010, 02:09 PM
You need to clear your 'going too fast' warning then mate
Old 27th April 2010, 03:33 PM
badger7777
Guest
Posts: n/a
My "going too fast" warning seems to be linked to passenger seat occupancy...
