Old 1st October 2010, 04:31 PM
Default ECU and battery Problems
The ECU managemnt warning light comes on quite often when i start the car or leave it on but not running the engine for a minute or so, sometimes it turns a few things
The battery meter is down to 10%, Several times it went back to 100% but goes back down if i use any electrics without the engine running.
I thought the battery may be old and have booked it in for a new one, however Im now unsure that it is the battery. I tested it today with a multimeter and found that it was at 12.6V turned the ignition to on for a minute , UCU warning came up, retested the battery still the same.
unlike others not once has the car failed to start or even had a problem starting. it seems to me the power is there but the computer doesnt think so.
If the battery Regulator is at fault it wouldnt charge the battery and the voltage would be drained.
where is the problem, is it likely to still be a battery problem?
Old 1st October 2010, 05:33 PM
What codes is VagCom showing if any?
Old 1st October 2010, 05:39 PM
Mkoneman's Avatar
Mkoneman Mkoneman is offline
yeah bring up measuring blocks in the engine controller and watch the battery voltage
www.facebook.com/obdworks
full genuine ross-tech vcds
full genuine vag- tacho
Old 1st October 2010, 05:46 PM
Thanks for the quick responce
Vag com is showing these to do with the batt regulator, these have been there before long before the ecu warnings though
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: ENERGIEMANAGER H11 0340
Revision: 00000000 Serial number: 00000000003460
Shop #: WSC 00847 210 56212
VCID: 204A67C68AB1
Part No: 4E0 915 105 A
Component: von VA0 390830U0EZ
Coding: 34453039313531303541205641303339303833305530455A
Shop #: WSC 00468 210 67755
5 Faults Found:
02273 - Quiescent Current Stage 2
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 8
Mileage: 136992 km
Time Indication: 0
Date: 2010.08.27
Time: 18:43:55
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Mileage: 136992 km
Time Indication: 0
Date: 2010.08.27
Time: 18:44:04
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Mileage: 136992 km
Time Indication: 0
Date: 2010.08.27
Time: 18:44:14
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Mileage: 136992 km
Time Indication: 0
Date: 2010.08.27
Time: 18:44:24
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Mileage: 137177 km
Time Indication: 0
Date: 2010.09.08
Time: 14:13:36
Im new to VAGCOM so didnt know about the measuring blocks in the engine controller, i will look it up and get the results
Old 1st October 2010, 06:35 PM
just had a look at vag com, im not sure what the relevant fields to use are, any specific instruction to measure voltage
Old 1st October 2010, 07:09 PM
When the engine is running just cycle through the measuring blocks until you find voltage readout.
