D3 - Engine Bay Everything under the bonnet |
I have these two fault codes:
005504 - Throttle Actuator (Bank 1): Malfunction P1580 - 008 - Implausible Signal 004203 - Throttle Valve: Stuck or difficult to move P106B - 001 - Upper Limit Exceeded - Intermittent Can someone point me in the right direction on which part to buy. It is causing a little arm to keep moving under the hood, which in turn is making a very deep "basey" sounding "hunt" on idle and when driving. I am assuming I can just replace the "bank 1" throttle body? Has anyone had or heard of this before? Any help greatly appreciated as I need this fixed asap. Bex. ![]()
07 Silver D3 A/S8L Quattro ![]() ![]() Last edited by A8L Chick; 14th October 2010 at 10:08 AM. |
Just to add the car isn't in "limp mode" and boosts fine, asides this annoying noise and slight (very slight) surging (and the light on the dash) the car runs fine
07 Silver D3 A/S8L Quattro ![]() ![]() |
The arm you can see moving on one bank may well be the actuator for the inlet port shut off valves. These can sieze up (especially if using cheap fuel) and the extar forxe required to move them causes the shaft that moves them to break! Remedy is replacing the inlet manifold on the effected side.
Could you take a pic of the arm you can see moving so we can be sure we're talking about the correct part. |
![]() Thank you. I have been using Shell Diesel Extra for the most part ![]()
BUGGER, I have posted this in the D2 section, my car is a D3 3.0 TDI QUATTRO... doh
Here are some pics of what is happening (please excuse the quality, I was rushing to get the pictures when the parts were in the 2 different positions so you can actually understand what I mean ) ![]() Ok this bit: ![]() And this bit: ![]() Which are here & here: ![]() Are doing this simmultaniously: ![]() to ![]() AND This: ![]() To this: ![]() They move in sync, as if they are connected somewhere under all the gubbins, and the deep bassey noise coming from the exhausts is also in sync with the "opening and closing / up down of these two parts....??? Confused ![]() I am ![]() ![]()
Thanks for putting this into the right section
