Old 17th December 2010, 03:49 PM
Trophy885 Trophy885 is offline
Default 3.7 40V starts, then stops.
Dear A8 gurus,
I have a 2000 3.7 V8 40 valve, which will crank, start, and then stops.
Coupled with this, the instrument cluster does not light up, and none of the gauges work.
Does anyone have any ideas?
The car has covered 80K miles, had a new battery (Bosch) in May '10, as the car only gets used occasionally, I wanted to "make sure" it would always start!!
Best Regards, and many Thanks.
Steve
Old 17th December 2010, 03:56 PM
Steve,
Welcome to the forum. Sounds like an immobiliser issue to me. I'm not an expert on the FL D2 immobiliser, but the instrument, ECU and keys are all matched and you have classic immobilisor symptoms there. Someone will be along shortly.
Old 17th December 2010, 05:33 PM
Try moving the steering column in or out by a bit and see if it makes a difference.
Old 17th December 2010, 07:26 PM
Immobiliser is built into the instrument panel which apparently is not working correctly so engine cuts out. Check the fuses and connections( short/open) to the instrument cluster. Disconnect battery for a while ( at least 15 min I would say) and see if that makes a difference after reconnecting. If the instrument cluster has gone bad You will need to replace it and have the immobiliser recoded which only few places can do apart from dealers. If You get a second hand instrument cluster with original key You can use Your key blade on that key and will only need to pair ECU with immo which is pretty simple and DIY if You have diagnostics cable.
Old 18th December 2010, 10:21 AM
Mr K Mr K is offline
Have you got a spare key you can try?
My spare key will unlock the cars, and start the engine but won't disable the immobiliser - so it starts and runs for a second then dies. I have no idea why it does this, but it could be you key that is at fault.
EDIT: just to add to that, my other key works fine. I need to get this sorted, will probably start by checking the key batteries (although they are new and it unlocks the car remotely OK) and then have a look at removing some of the steering column.
Old 18th December 2010, 01:07 PM
Mr K
Battery in the key is for remote only. Transponder for immo works without battery. It gets power wireless from sender/receiver unit in the car.
Your other key does not work because it is either not coded into immo, is faulty or have a weaker signal and poor connection causing weaker signal not being read properly.
Old 11th February 2011, 08:26 AM
This wont help you - but I got some time to play with mine yesterday (see page one of this thread) and realised that the chip is in the top half of the key, next to the blade and not in the remote section. When I built the key into the new case I left the chip in the old bit! refit the old bit and its all happy!
Old 20th December 2010, 08:26 PM
Hi Ainarssems,
many thanks for the info, as I say, I shall be checking this gen out.
Any chance it could be the "antenna" on the ignition switch, as it normally behaves itself just after the battery has been charged and re connected.
Best Regards,
Steve
Old 22nd December 2010, 03:16 PM
Hi PsYcHe,
Thanks for your advice, I have checked this out, sadly, as nice an idea as moving the wheel was, it was sadly to no avail.
Many Thanks once again.
Best Regards,
Steve
Old 22nd December 2010, 05:46 PM
I missed the dead cluster bit in the post. I'd pop the cluster out (procedure is on audipages.com) and check the connections on the back, but it's sounding like your cluster may be dead
You did check all the fuses as well?
