Old 19th January 2011, 03:43 PM
christhompson's Avatar
Default How to remove D2 cd changer
When I bought the car the previous owner had installed a Pioneer AVIC and happily retained the Bose speakers. Thus I have a 6 cd changer in the boot cubby not connected and not used. I could use the space. How do I take it out without trashing other connections? Is it worth anything when I do get it out?
Old 20th January 2011, 06:15 AM
graynada graynada is offline
It comes out really easy just a few screws if I remember right. Mine was attached to a frame that also holds the telephone unit. If you are not using this you can remove the whole lot by removing four allen headed bolts screwing it to the boot deck. The cabling all disconnects easy and can be fed down to the space below where the amp is leaving you a nice clear cubby hole.
Interested too to know if it has any value as it is sat in my shed with the head unit (no code) gather dust.
Old 20th January 2011, 10:11 AM
There are indeed 4 bolts which when undone allow the plate/frame holding the changer to lift out. The cable unplugs - job done. Many thanks.
Underneath the player is a ribbed metal box - this is the power amplifier I guess, but not for the AVIC I suspect. Its deep in the cubby so I guess I'll just ignore it.
However as there have been no sniffs of interest on this site, I guess there is little or no value to the changer in these days of mp3 players.
Thanks again
Last edited by christhompson; 20th January 2011 at 10:17 AM. Reason: to make better sense!
Old 20th January 2011, 04:05 PM
Yup, Bose amp is situated in the recess below the CD Changer, effectively in the opposite slot to where your battery is on the other side...
The changer is VW/Audi/Skoda/Seat generic for that era, so you'll probably get a little interest on fleabay for it
Old 20th January 2011, 04:39 PM
Paperweight then!
