Old 13th March 2011, 03:35 PM
Default ABS Failure
OK Guys,
My ABS has failed Reporting Right rear sensor implausible signal. I've replaced the sensor, but it's still giving me errors.
I did (probably stupidly) click the 'output tests' button in VCDS, and now it's telling me the controller is faulty. It does respond to VCDS, and it does read the speed from the other 3 wheels.
Any ideas beyond a new ECU (and where is it? might want to have a look inside and see if I can spot a dry joint or test for cable continuity).
Old 13th March 2011, 04:02 PM
Swap the sensor onto another wheel Richard and see if the fault goes with it. If not I would suspect wiring before control module.
Old 13th March 2011, 04:06 PM
You'd think .. But the sensor only fits one wheel on the D3!
I found the control unit (it's on the back of the ABS block in the engine bay), disconnected the cables from it and will re-check later to night if that's sorted it.
If not, then it'll need to go in to A4Audi as I haven't got time to fart around any more
Old 14th March 2011, 05:11 PM
Just_Ben Just_Ben is offline
Try popping the sensor out and seeing if the reader ring is full of crud or rust. This can totally impare the signal. Or if the mount is coroded/bunged up the sensor sometimes doesn't sit fully home and the resultant larger air gap ruins signal too
Old 18th March 2011, 06:53 PM
Turns out it's a failed wheel bearing.. That noise I thought was just the tyre worn out was the bearing being gubbed, and it had reached the point where it was so far out of position it was missing the sensor..
Pretty common mis-diagnosis apparently. Another great job by A4Audi
Car is much quieter now, and no longer sounds like a cheap 80's rave when it starts up
Old 19th March 2011, 01:40 PM
Well only when you play your smash hits CD's
Glad you got it sorted ok
Sounds like you boys up there have a great Garage in A4 Audi
Old 14th March 2017, 03:10 PM
Default What comes around, goes around ...
Thanks PsYcHe, if you're still tuned in these days.
I had exactly the same issue; same wheel. ABS / ESP/ Parking Brake alarms and VCDS showed me that Right Rear ABS data was 'missing' from the ABS ECU. I put up with for them for two weeks until my trusted service guys could fit me in and suggested that they check the wheel bearing.
Bearing replaced; all DTCs and alarms cleared and gone ...
This is such a great forum ...
Julian
