Old 21st March 2011, 08:24 PM
s2_bo s2_bo is offline
Default Is 245/40/18 a no go?
The S8 i bought recently came with 245.40.18 and not 245.45.18 tires like its supposed to have.
They look a bit small as they dont fill out the arches as much..
Should i change them asap or is it ok to keep them on until they are on the wear indicators?
Thanks.
Bo
Old 21st March 2011, 08:33 PM
see the attached image
if they are all the same size then your speedo will just indicate you are doing faster than you actually are by 2.2mph and you can just wait until they are worn down to renew with a new size but again you will need to do all 4
if you have different sizes on front or back and quattro then you may get more of an issue!!
Old 21st March 2011, 08:40 PM
Thank you that's very useful info.
They are all the same size but the spare is 45.
Would it damage the diff to use one 45 on a set of 40s for a short period of time should i have a blow out?
Cheers.
Bo
Old 22nd March 2011, 10:05 AM
I don't think it would damage the diff but the car would sense the differing wheel speeds and think you were encountering a slipping wheel situation so not sure what the electronics would make of that.
Old 22nd March 2011, 12:03 PM
It definitely wouldn't be recommended running the spare as it stands.
How much tread is left on the old ones?
Old 23rd March 2011, 07:00 AM
The 40s have 5mm the spare has 3mm.
Thanks.
Bo
