Old 1st April 2011, 11:14 AM
A8L Chick's Avatar
A8L Chick A8L Chick is offline
Default Running cold issue. Tricky one-thoughts needed
My silver '8 has been running a little "cold" recently. I originaly thought "ok, time for a new thermostat, water pump & belt".
I had the above sorted yesterday using all OEM parts and the problem still persists. Mainly during motorway use, and it seems to run even cooler when using the a/c cc.
I have no problems with heat in the car, heaters work just fine, no water leaks, water levels are fine and system was bled properly, taken for a warm up run and then re bled to be safe.
The needle isnt jumping around arratically which makes me think it's not a temp sender fault. Could anyone point me in a few directions of other parts that could be to blame for this odd temp behaviour.
Bex
07 Silver D3 A/S8L Quattro S8 front end, Xenons, Bose, Bluetooth, Voice Control, Autodim mirrors, Heated folding mirrors, Double Glazed Windows, Electric Rear & Side Blinds, Black leather Comfort Seats with front memory seats & mirrors, Front & rear heated seats, Interior/Exterior light pack, TV.I.M, AMI, Parking sensors Front & Rear, Air suspension (soon to be lowered), Keyless entry & Start/Stop, 4 zone climate control, Power Boot Open/Close.
Last edited by A8L Chick; 1st April 2011 at 11:15 AM. Reason: spelling for a change
Old 1st April 2011, 12:59 PM
not sure bex but love the new sig pic!
Old 1st April 2011, 01:17 PM
Awesome sig pic, not sure about the engine. Ben/Mike/Physce/A8Doc will probably know.
Old 1st April 2011, 01:36 PM
Could still be temp sender, but if it's going to a normal place whilst idling/town traffic, and then dropping when going fast, it may not be.
Maybe the fan staying on when it shouldn't. Does it behave with the climate off or set to econ mode?
Old 1st April 2011, 01:41 PM
A8L Chick's Avatar
Thanks for the sig comments chaps I have a few new pics I rather like.
Yes I think it does go back to the normal 90 (middle of dial) during town driving.
I will confirm later but I am pretty sure that when using econ, temps remain normal.
I will update a little more tonight after work.
I was thinking the fan may be staying on-but I cant hear it when I pop the bonnet
Old 1st April 2011, 03:52 PM
Can you put VCDS on it and check the temperatures from the senders.
The drawings show you have twin electric fans. If one were not switching off that might cause the problem. But running cold usually means thermostat issues of temp sender issues.
