I was told by the previous owner that my S8 has a " Sport Exhaust "...
Any comments or advice ?? There is Mod installed..... being a rocker button instlled under the Centre Armrests..... Apparantley this controls Flaps in the Exhaust... quote previous owner " Alan - Before you reroute the magic switch, check the rear exhaust actuator...see if there is a spring connected (between the rear diff & last box)...I saw my son play with a spring last week that could be that one from the S8. " I am going to re-route the wiring going to the Engine Bay as it is partially exposed at this point but wouldn't want to go to that hassle if it is not working.... From Prowler to Track Hooligan at the Push of a Button... Hmmmmmm A short clip: http://youtu.be/XL1OVoH9CRk More to follow..... |
sounds very nice
Audi S8 2015, Daytona Grey Last edited by briang9; 29th June 2011 at 07:50 PM. |
take some pictures and post them up, none of the D2 models came with any kind of valves in the system so that is totaly after market and has been installed by the last owner im looking into doing this myself at some point its fairly easy to rig up on a standard system
Sounds ace
![]() ![]() 2002 Aqua Blue S8 with Milltek - Now sold ![]() SL55 AMG Silver with designo red leather and 20" Carlsson 1/16 Utlralight Wheels |
I'll be taking it in today to my local Zorst man and put it up on the hoist and see what the deal is....
I'll take some Pics and post them later. Vid Clips of the On/Off Flap to follow. ![]() Last edited by Iyole; 29th June 2011 at 06:58 AM. |
Decided to pop down to the local Powerflow this afternoon and have a chat to Roddy.......and find out what is causing all the fuss about the S and her tendancy to cause Pedestrians false teeth to rattle and every Rice Racer want to take Her On....
Arrived there.... straight on the Ramp..... Inspection.... the whole garage downs tools to look see..... This is what we Found.... ![]() ![]() ![]() ![]() ![]() ![]() The way I see this is that the The Flap Type Valve shuts off the one pipe when in Prowl Mode hence the additional silencer on the one pipe and larger rear Silencer ....... and Resonator ??? There is a rocker button under the centre armrests to contol this flap..... so I understand... This does not appear to be operational..... Roddy feels the existing configuration is restricting the output ..... Has given me a Quote to replace entire system in stainless... Offered to re-plate the existing tips...... Cause I don't wanna change them.... I am keen to get the pipework re-done in stainless...... but keep the existing boxes, ...resonator.... , Up-Graded Flap Valve (operational) .... I really like the sound of the existing set-up and wouldn't want to loose that.... Stay as Is Replace pipework only Replace entire system... Any comments..... advice... Tx. ![]() Last edited by Iyole; 29th June 2011 at 06:49 PM. |
