Old 3rd July 2011, 12:40 PM
Default is there a guide on changing full suspention ?
just wandering as im going to tackle putting the S8 shocks and springs on i have them all set ready just need to swap out the complete units on the front and the shocks and springs on the back i have A8 retro fitting S8 srings ect ... ?
many thanks
Old 4th July 2011, 10:02 AM
is any one willing to help with this ? dont want to end up with the car sat on the drive with no springs lol im all for diy but if i cant find a guide or anything i will just pop it into the garage ;-)
Old 4th July 2011, 10:44 AM
Should be a straight change over.... Just make sure you have some coil compressors to hand or you'll never be able to get them back in....
Old 4th July 2011, 12:52 PM
On the front it's quite easy if you have the springs mounted on the struts already. You can remove the 2 lock nuts that hold the strut into the top control arm carrier from inside the engione bay. Undo the nut and slide out the bolt from the lower control arm and you can jiggle the strut out and replace.
The after end can be a bit harder and a lot of typing so give me a call and I'll talk you through it. Did Chrisp17283 this morning and his whole front end on Saturday. Before anyone else says anything, yes we did get the rear lower control arms on the wrong way round!!!!!
Old 5th July 2011, 04:27 PM
Just remember that any bolts that go through rubber bushes need to be tightened when car is with wheels on ground and suspension in normal driving position
Old 8th July 2011, 04:37 PM
any reason why its embossed A8 on my new s8 springs and dampers ? or is that just the product line that it fits ?
might have a look on vagcat
