My ECU and ABS light have been coming on intermittently the past week. I also found a small amount of Fluid on my Garage floor.
On investigation I found a leak from one of the pipes on top of the pump. Would tightening this nut resolve the problem.....do I need to purchase a new pump (Serious Dent in my ![]() ![]() Thanks Guys |
For the leak just tighten up nuts. Have seen this happen on several different cars, if just tightening does not help release a bit( not too much so that air does not get in) and tighten again.
ECU and ABS lights probably are not connected with this, read the fault codes. |
Thanks Mate
