Old 26th February 2009, 09:49 AM
DJStrange
Guest
Posts: n/a
Default Engine light on, misfire, knocking
Just took my 8 up to the shops, noticed a misfire via putting it in drive and it not being a smooth "bite" - more of a jerking movement. Got to shop (2 miles), noticed it again when reversing. Drove back to work, idling down the car park with the window open, there's a light knocking sound and now the engine light's come on.
I pipped the bonnet and had a listen, I can feel the knock on the top of the engine, the right side near the oil filler, but it doesn't get louder when I take the filler cap off. Sounds like someone tapping a margerine tub. I'm gonna get someone to give me a lift home to pick up my laptop and use vagcom for the first time.
Questions:- what would it sound like if it was a simple misfire (electrical/fuel)?
Anybody know what it would sound like if there was a sticky valve?
More importantly, does anyone know what this is likely to be or have you heard a noise like it? Does it come across as serious? I'm panicking now as I have to tow my caravan 25 miles up the road this weekend.
2002 S8. Any help/insight/advice appreciated - I'll also update in a bit with the vagcom results...
Old 26th February 2009, 09:53 AM
Could be something really simple, but no point hypothesising - The good thing is that the warning light is on, which means the engine ECU will have logged something. Get Vagcom cranked up and see what the error is and take it from there
Old 26th February 2009, 10:42 AM
My money is on an injector........ Any takers?
Old 26th February 2009, 12:12 PM
DJStrange
Guest
Posts: n/a
Cleared the old codes in vagcom (usual stuff, random misfires, misfire on 6, gear selector intermittent - stuff that was on last time it was read over 6 months ago). Started her up again, sat for a minute, no engine light. Switched off, plugged in, no fault codes.
Spoke to Autopool in Iver, at first he said maybe a broken rocker or a bucket (cam belt & cams out), then he had a listen over the phone and reckons it could be a spark plug loose or pushed out. Basically he said in no uncertain terms, don't run it. Get it on the back of a recovery vehicle and bring it in. Mentioned helicoiling and broken injector. I've never worked on the engine yet, so I haven't a clue - I'm just glad it still runs and I didn't drive too far with the noise. I'm also glad I didn't drive straight down to see him about it.
RAC called out, should be here within an hour.
Keep fingers crossed, he's got me a slot for tuesday/wednesday, so should know more then.
Now to find a donor vehicle with a towbar for the weekend...
Old 26th February 2009, 12:22 PM
Hmmmmm spark plug pushed out? Random Misfires, Misfire on 6. Maybe a quick check of the right hand bank as you loook into the engine bay. Whip of the cover (2 x 5mm allen bolts), remove coil pack, 10 or 12mm hex and stick a plug spanner in to see if its tight.
Old 26th February 2009, 12:38 PM
DJStrange
Guest
Posts: n/a
I would do, but I'm at work at the moment, already had 2 hours getting my laptop & doing the vagcom. I've got my entire tool kit in the boot too after getting my brother's mini engine running last weekend - wish mine was as simple!
Might have a word with the boss, see if he'll let me have a bit of time to look it over before RAC get here with the flatbed.
