I was trying to change the instrument cluster but ended up losing power to my live feed.
I tried to check fuses in the driver's footwell but anything instrument related looks fine...can someone tell me where the wire goes...cos I tried chasing the wire back behind instrument cluster but it is very difficult to follow.... Any help in resolving this issue would be very much appreciated. Thanks Ranjeet |
Well my problem was a blown fuse...in particular location 4 in yellow block....I found it by doing a continuity test across all the fuses...
I attached one wire on the live feed from the multimeter and the other end I touched the tops of the fuses until one of them gave me a continuous beep...then I found my culprit... This fuse had a completely random name on the fuse diagram...so it wasn't obvious this was the problem. |
