Old 15th January 2012, 07:52 AM
Stuarta Stuarta is offline
Default Finding leak in air suspension
Anyone have any advice on how to find the leak?
I'm still a newbie A8 owner and all was well until this morning when I had the dreaded flashing icons - this is what vag-com said:-
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0015510
Shop #: WSC 02313 785 00200
VCID: 2855E99BE263
3 Faults Found:
01583 - Leak in System Detected
000 - -
Freeze Frame:
Fault Status: 11100000
Fault Priority: 3
Fault Frequency: 74
Reset counter: 55
Mileage: 60487 km
Time Indication: 0
Date: 2011.12.05
Time: 14:38:24
01577 - Turn-Off due to Over-Temp
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 4
Fault Frequency: 24
Reset counter: 95
Mileage: 61176 km
Time Indication: 0
Date: 2011.12.29
Time: 11:02:55
01400 - Suspension Level Control
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 11100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 55
Mileage: 61581 km
Time Indication: 0
Date: 2012.01.15
Time: 11:27:51
I tried clearing the codes but they all came back straight away.
I'm assuming that the over-temp is due to the compressor being taxed to overcome the leak - question is, how to trace the leak?
Old 15th January 2012, 08:31 AM
Possibly luck... Let it all cool down and listen at each corner to see if you hear it, otherwise it's garage time.
Old 15th January 2012, 09:13 AM
I would put some washing up liquid (or foamy car shampoo probably kinder) into warm water in a bucket and then use a beaker or such like to throw it over the pipes, dampers etc... Maybe an older household sprayer would be helpful too. If there is a leak, you should see cuckoo spit forming.
Old 15th January 2012, 10:11 AM
Seems to be sitting much lower at the front - so I'm hoping that'll narrow things down! Will try to have a look later today. Thanks.
Old 15th January 2012, 10:39 AM
Fingers crossed it's something easy and not a blown shocker (though A8parts have them in).
Old 15th January 2012, 12:14 PM
OK - had a listen and can definitely hear something at the front - will need to wait for tomorrow to jack her up and have a look. Rear sounds fine.
Incidentally, I have often noticed a hissing noise from the front when getting out of the car and assumed that it was the system venting pressure on shutdown - I assume then that it's NOT normal?
