A8 / S8 Generic Posts All other useful info |
Hello guys!
Just a quick query here. If an S8 D2 has a manual transmission installed, and the ECU isn't coded for manual (so it doesn't look for the absent TCU) what problems are encountered? Will the engine RPM and torque be limited? Thanks in advance.
2006 Audi A8 D3 Quattro Sport 4.2 TDI - Silver, Family Oil Burner. 2000 Audi A4 Quattro Sport 2.5 TDI - Santorin Blue, S8-Powered DTM Race Car Build In Progress. 2000 Audi A4 Quattro Sport 2.8 30V - Pelican Blue, RS4 Widebody, D3 4.2 01E, High-Spec B5 Build In Progress. |
I think it just gives you loads of errors but works. See if you can hunt down some of Tozo's threads on quattroworld, he went through that process.
^^^ Yes, I'm aware the ECU would be annoyed. Just wondered if the engine RPM will be limited. This is a pre-facelift S8, AHC motor code.
From memory, there were no other issues with it, just the errors about (or possiby from) the TCU.
^^^ I've PM'd Tozo.
I'm not sure if he's done a manual conversion on the earlier 32V motors. Looking through his posts, I can only find his black S8 40V, as well as a couple of other A8's, also 40V.
Is there a knack to using Quattroworld? I can't seem to be able to view complete threads, it just appears to be single replies.
