Hi all, i'm new to the forum as you can probably tell.
I have just purchased a 2001 S8, unfortunately since the cold stint of weather we had my car (when cold) will not select reverse?? Once the engine is warmed up and i have driven for a bit its absolutely fine. After reading up on the net a bit i decided to change the gearbox oil and filter (have used Audi genuine parts). My mechanic friend helped me to do this and also recommended using a small part of the old oil as using totally new oil may block the filter very quickly and cause big problems. I plan on doing another oil and filter change in about 500 miles. The car now changes gear alot smoother but i still have the problem!! My friend told me that i need to use the car a bit more to circulate the oil more through the reverse gear valves. Has anyone else had this problem?? My car has done alot of miles 180K but has a full Audi service history. I only paid 1500 for the car so don't mind spending a bit on it as long as i'm spending on the right thing.. ![]() |
Reverse failing is a common problem on the FL gearboxes. It's the Clutch F seal if I remember rightly. You could go for a rebuild or a new box for about £2500 all in which would do you for a good bit longer
search the forum for F125 switch. I seem to recall someone having a tempremental switch in cold/wet weather causing some issues might be worth a check to see if they sound similar to yours. If not then unfortunately it could be what he ^ said :C or several other gearbox based gremlins all of which would require a specialist to diagnose properly.
PF late '97 D2 2.8 Aluminium Silver. Solar roof, Full Heated Leather, Double Glazing, 17" wheels, Sports Steering Wheel, Cruise, Blinds, Bose sound. ![]() Fiat Tipo diseasel econobox with all the buttons and none of the soul that now does all the heavy lifting. Ford Capri Laser: noisy, slow, thirsty, bouncy, no buttons but it always sounds like it’s REALLY trying and I can’t help but chuckle when it parps and boings along. And people of a certain age stare at it with a wistful look in their eyes that clearly says…I had one of them. And I sold it because of the kids ![]() Last edited by B@fink; 17th February 2012 at 10:04 PM. |
Do all the gear related lights in the DIS display turn red when the problem occurs? If so, it's logged a fault and gone into limp mode - that means there's a stored fault to read.
Doubt it's the F125 switch - this sounds more like a mechanical fault as mine would still work in reverse fine with a duff F125.
I had a duff F125 switch. It made a hulluva noise in reverse and in other gears when cold, but it worked fine. A VagCom would diagnose this. That's the essential first step IMHO
Hi and welcome. What part of the country are you in? There maybe someone close that could plug it in for you and see if it has logged errors.
Oh and photo's of the car please
