Old 6th March 2012, 12:57 PM
Default Long brake pedal
At least that's what my ex-garage-owner mate who just had a look says I should describe the problem as.
The brakes on my 1998 S8 feel pretty soft and not wonderfully effective; you have to push hard and a long way to get a rapid stop. No warnings.
My tame "expert" had a quick look and said, yes not working as they should, need attention sooner rather than later.
He did confirm that the rear pads were new (done late last year) and fronts had loads left. No signs of any leaks and the reservoir is full.
His opinion is that it was probably an internal leak in the master cylinder and that replacing it as a unit was the most likely solution.
Does anyone have a view on whether that is likely and if so how big a job is it and how much for parts and labour at an independent Audi specialist?
Thanks in advance.
Old 6th March 2012, 01:25 PM
Also how old is the fluid and when was it last changed? Brake fluid is recommended for a change every couple of years these days.
Old 6th March 2012, 01:29 PM
Fluid was changed at the last service, when the rear pads were fitted.
(along with a load of other stuff that was done - t'was expensive!)
Also the brakes were fine a couple of weeks ago when I last drove it.
Old 6th March 2012, 05:15 PM
S4Phil's Avatar
S4Phil S4Phil is offline
How much of an 'inspection' did he make?
Check:
Brake flexi hoses
Brake pipes (condition and for leaks)
Calipers for leaks
ABS module for leaks
Old 6th March 2012, 05:20 PM
It was only a quick look with a torch - no ramp available.
I've got it booked in for investigation this Friday.
(where it was last serviced - Fontain in Iver)
Old 6th March 2012, 05:33 PM
47p2's Avatar
47p2 47p2 is offline
Flexi hoses would be the first thing I would check, have someone press the pedal whilst someone checks each hose for bulges
Nite Blue 3.0L SE Quattro
