Old 8th March 2012, 12:28 PM
Default Sports mode and 6th gear.
I'm convinced, really really, sure that when I had my 2003 plate 4.2 D2 that if you put it into sports mode on the gear selector, and then attempted to change gear with the paddles on the steering wheel, that it only showed gears 1 to 5.
I'm also convinced this was the case with my recent B7 S4.
You put it into sport, and it forgets about 6th gear. Not unreasonable i guess if you're being really sporty.
But - My new D3, a 2006 3.0 Tdi definitely does not lose 6th gear when you put it into sports mode. This is really very good, as in Drive its a bit too sluggish for my preference, but wouldnt want to drive in Sport all the time if it was never going to use 6th.
I'm 99% sure I tested this on Richards new 4.0 and it didnt lose 6th either.
So, Is this an age thing - Or a petrol / Diesel thing ?
Can those D3 owners out there with flappy paddles please test and report back for my sanity please?
Old 8th March 2012, 01:14 PM
AusA8 AusA8 is offline
D3, V8 petrol, MY03/4 - 6th shows in Sport mode.
A8 4.2 S
Old 8th March 2012, 02:59 PM
My 4.2 Petrol doesn't show 6th in 'S' when you use the paddles.. Need to check the 4.2 diesel later.
Old 8th March 2012, 03:04 PM
My A7 shows 7 gears in both D and S mode and 7 in Manual mode when you switch to it or when you over-ride D or S with the flappy paddles
Old 8th March 2012, 09:45 PM
My D3 S8 can still change up to 6th in S mode. It just chooses to ignore it for most of the time
Old 8th March 2012, 09:54 PM
kal_ay's Avatar
kal_ay kal_ay is offline
What he says ^^^^^^^^^
2002 D2 S8 Misano Red
1996 Volvo 850R Estate Red
2013 Mercedes C63 AMG (taxi)
1991 Lotus Carlton Imperial Green
Old 26th July 2012, 01:36 PM
A8Jas A8Jas is offline
Yeah my 2007 D3 3.0tdi shows 6 in S mode and you can flap up to it. Doesn't shift into 6th automatically much though - maybe I'm not going fast enough!
Old 31st July 2012, 09:38 AM
My d3 w12 dose show all 6 gears in sports mode when using the paddles
Old 22nd August 2012, 05:37 PM
2006 D3 3.7 petrol
No 6th gear when in sport, auto or paddle shifters.
But when in Sport and Cruise Control activated the 6th gear appears straight away.
I assume Sport mode isn't design for a long steady journeys, just a fast road use with plenty of up and down shifts in a short time so software is not even bother to display the last gear as you should not even get that far if you are really in a Sport mood
Old 23rd August 2012, 06:19 PM
Mutley Mutley is offline
2003 D3 4.2
6th gear shows in sport, normal, and paddles\tip
